brake problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by 604YOTA, Jun 1, 2014.
  1. Jun 1, 2014 at 11:26 PM
    604YOTA
    604YOTA [OP] Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    So iv been having some problems.
    First when I am going down a long hill my brakes are always firm.. they seem to be getting way to hot..I am on my 3rd set of rotors and pads in 2 years they keep warping
    I have been thinking of cross drilled rotors..will they help cool?
    Back to the hill thing i don't have stopping power. I am affraid of getting behind someone and them stopping all of a sudden what can I do...
    When on switch back and going down hill I put my foot on the brake and it has very minimum effect on stopping brakes won't lock up and abs won't kick in..
    Any ideas?
  2. Jun 1, 2014 at 11:41 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Steel brake lines, new brake fluid, all new pads and rotors
  3. Jun 1, 2014 at 11:46 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Hmmm. Sounds like maybe something wrong with the abs, booster or maybe vacuum. Strange that your going through brakes so often. Could be something simple like air in the lines.
  4. Jun 2, 2014 at 6:17 AM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Iv done a full flush and 're bleed no air in the system. I don't want to go throwing a new set of rotors on and be back to square one in another 6 months.
    But maybe it is that they are heating up amd getting a glaze on them?
    Should I try a slotted and cross drilled rotor?
  5. Jun 2, 2014 at 6:33 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Is that vacuum line to the booster in good shape and sealing well?
    Slotted and drilled rotors have less mass and won't soak up as much heat. But thru will cool better. I'd stay with blanks. Make sure the rear is helping. Make sure nothing is seized in front
  6. Jun 2, 2014 at 6:33 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Sounds like maybe your calipers are starting to seize.
  7. Jun 2, 2014 at 7:29 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    3rd set of pads and rotor's in 2 years?. wow!. I wouldn't buy cross drilled anything until you make sure that the braking system is right,,and it doesen't sound right at all with that record.
    Vacuum booster operation needs to be checked. Sounds like it is non existent, or possibly you are having abs probs.
    A blockage or restriction of some sort.
    Getting it to stop,, or lack of,,is probably glazed rotors and shoes from standing on the pedal to stop.
  8. Jun 2, 2014 at 7:56 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I know this may sound stupid but do you clean the glaze off the rotors before you put them on (with brake cleaner or lacquer thinner)?
  9. Jun 2, 2014 at 8:06 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    How fast are you driving? The brakes on the 1st Gen Tacoma are not very good in the first place. They do not last in heavy use, I replace pads and rotors every year. I would go through the whole brake system first, make sure rear brakes are adjusted properly. Also look into the Tundra brake conversion for the Tacoma.
  10. Jun 2, 2014 at 9:22 AM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    People need to keep in mind that in bc canada nothing is flat lots and lots of hills...
    How do I check to see if my vacuum booster is work in proper?
  11. Jun 2, 2014 at 10:25 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Colorado ain't very flat either :) I've only changed pads once in 100,000 miles.
    I really think your calipers are seized. But I could be wrong... Hard pedal, and warped rotors tell me the calipers aren't releasing or compressing as they should.
  12. Jun 2, 2014 at 10:54 AM
    Madjik_Man
    Colorado Front Range
    Taking a wild guess here:
    You look lifted. Did you get a BPV bracket to ensure the proper braking?
  13. Jun 2, 2014 at 10:58 AM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    yes I did get one.
    As for my vacuum booster I did the check as per the fsm and all is air tight.
  14. Jun 2, 2014 at 11:09 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    2 questions I want to throw out here:
    1.) Did you grease the Calipers when you did the Brake Job?
    2.) Is your Gas Mileage crappy?
  15. Jun 2, 2014 at 11:12 AM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    I get 14 mpg I have 33s .also cant remember if I greased
  16. Jun 2, 2014 at 11:43 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Then jack that front up and spin those tires. If they do not spin freely then the Calipers are toast.
  17. Jun 2, 2014 at 12:34 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    They do spin free
  18. Jun 2, 2014 at 12:47 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Convert to 2005 Tundra brakes. Problem solved for under $300.
  19. Jun 2, 2014 at 6:04 PM
    40950
    CR, WA
    stock
    Vacuum booster is good,,check that off.
    Those with ABS,,is there a fuse underhood?, because I don't have abs.
    Do you haul alot of bed weight most of the time?, If so how much?.
  20. Jun 2, 2014 at 6:48 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Maybe 600lbs of camping gear every couple weeks. Otherwise its empty
