brake problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by 604YOTA, Jun 1, 2014.
  1. Jun 2, 2014 at 6:55 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Tundra calipers/rotors swap, some new pads and you will be good to go.
    Stay away from anything BUT solid steel rotors, especially if you wheel. Your lift combined with your larger tires and rims setup is overtaxing your stock brake setup which is the reason for terrible braking power. You may want to consider swapping out the fluid as well. Unless you have high mileage on the brake lines and they look like they are beginning to deteriorate and crack I would leave them.
  2. Jun 2, 2014 at 7:44 PM
    TacomaTRD4x402
    TacomaTRD4x402 Well-Known Member
    So Cal
    '02 Tacoma TRD 4WD 3.4 5spd S/C Long Travel
  3. Jun 3, 2014 at 6:29 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Are you using aftermarket rotors? My tacoma hates anything but oem. Are your rear brakes working properly? Sounds like front brakes are doing all the work. I don't know if you have to but, I always clean film off with brake cleaner since I always have can available doing brake work.
  4. Jun 3, 2014 at 6:41 AM
    SlipperyTaco
    SlipperyTaco Slippery when Wet
    Chandler, AZ
    04 Tacoma 4x4 & 2014 4Runner Trail Premium
    FOX 2.5 C/O, CAMBURG UCA, FOX 2.0 REAR, SMP CUSTOM FRONT BUMPER, BAMF LCA SKIDS, SCS RAY 10 MATTE GREY WHEELS, 305/70/16 BFG KO2, ALL PRO STANDARD LEAF PACK, ALL PRO SLIDERS, U-BOLT FLIP KIT, MARLIN CRAWLER REAR BUMPER, TIMBREN REAR BUMPSTOPS, WHEELERS SS BRAKE LINE F/R, D-BADGED, GIBSON CAT BACK, K&N CAI, LINE-X , GREY WIRE MOD, APOLLO 3.0 SHROUDS, D2S XB 5500K HID BULBS, LED HALOS, LED DEMON EYES, TRS LED BULBS, BHLM, IGGY PODS, CALI RAISED PODS, 30" CALI RAISED 4D LIGHT BAR, BESTOP SUPERTOP, TRASHAROO , WET OKOLE SEAT COVERS. 4 RUNNER- 2014 TRAIL PREMIUM W/KDSS KINGS FRONT AND REAR DIRT KING BALL JOINT UCA METAL TECH LONG TRAVEL SPRINGS METAL TECH UPPER/LOWER LINKS SONORAN STEEL KDSS TRACK BAR URD EXHAUST URD Y PIPE URD MAF CALIBRATOR PEDAL COMMANDER PRINSU ROOF RACK RIGID ADAPT LIGHT BAR SCS SR8 17" GUNMETAL 285/70/17 FALKEN WILDPEAKS TRS FOG LIGHTS TRS HID KIT SS OFFROAD SLIMLINE WITH SIDE PROTECTION COASTAL REAR SWINGOUT HEFTY FAB SKIDS
    that seems like a lot of wear for brakes. i dont know if it is because i have a manual and that saves my brakes a lot.. i have only replaced my brakes twice since 2005..But i know your crazy canadian weather is a lot worse then i have it hear in so cal.. here is what i would do Tundra brake upgrade or go with smooth rotors do not get slotted that just lets dirt and debris get caught up in the holes and get EBC green stuff pads!:)
  5. Jun 5, 2014 at 10:21 PM
    604YOTA
    604YOTA [OP] Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Going to throw some new pads in for now..and track down some tundra calipers and rotors. When iv got a bit more cash.
