Brake Proportional Valve: Adjustment
Discussion in '1st Gen. Tacomas (1995-2004)' started by sirsaechao, Jul 28, 2012.
  1. Jul 28, 2012 at 10:07 AM
    sirsaechao
    sirsaechao [OP] Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Just installed my Wheeler's 5 pack and BPV from Wheeler's and I first notice when even at slow speed over a speed bump if I hit the brakes the rear locks up causing my tires to squeal. This morning I almost ran a yellow light but I stopped from 50 to 0 and my ass end was going left right and tires again squealing. How do you adjust the rod? I know the lower it is the less braking the rear has but what rod am I supposed to pull down on? Thanks.
  2. Jul 28, 2012 at 11:41 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Raise the BPV with a bracket, there not that difficult to make, if you raised the rear 2 inches raise the BPV bracket 2.
  3. Jul 28, 2012 at 11:50 AM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2007 DCSB SR5 4X4
    Here is a link to the BAMF BPV relocation bracket.
    Link
  4. Jul 28, 2012 at 12:44 PM
    sirsaechao
    Tim
    Commifornia
    I guess you both don't understand my question. I have a bpv bracket for my 5 pack. I think the bpv bracket raised it to high for the amount of lift I got from the new leaf pack. I need to bend the rod down more = closer to axle = less rear brakes. I just don't know which rod I am supposed to bend down.
  5. Jul 28, 2012 at 1:19 PM
    tacoma04
    Bruce
    Northern Louisiana
    2007 DCSB SR5 4X4
    So the bracket doesn't have multiple holes to let you select the height of the valve like the BAMF bracket? Everyone just matches the height of the lift and no problems. Can you drill additional holes in your bracket to lower the valve?
    There is an adjustment for the valve. I read it in the FSM once, but don't remember if longer or shorter increased or decreased braking.
    Edit: here is a link to the FSM. Look at page BR-47. Does that address your problem?
    Link
    Got a pic? Might help us understand.
  6. Jul 29, 2012 at 7:13 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Post a picture of that BPV bracket.
  7. Jul 29, 2012 at 10:19 AM
    sirsaechao
    Tim
    Commifornia
  8. Jul 30, 2012 at 5:55 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    I don't know how much rear lift you gained but to me it appears the bracket that mounts the BPV is way to high I would measure where I was at before installing the bracket ( rear vehicle height ) and would lower it, as necessary by drilling more holes, not bending or adjusting any thing.
  9. Jul 30, 2012 at 6:10 PM
    nswsparky
    nswsparky Well-Known Member
    Chad
    Minnesota
    '03 TRD, SAS, ARB's F/R, Atlas 4 speed
    D44, SAS, 3 link coilovers, ARB's, Ford 8.8, Atlas 4 speed, cutting brakes.
    well you think about it if your brakes are locking up on brake application it thinks you are fully loaded and squated out. make the rod shorter so it enters the valve at a downward angle.
  10. Aug 1, 2012 at 9:06 AM
    sirsaechao
    Tim
    Commifornia
    I ordered BAMF's bracket but I think I might try not even running one. I got about 1" lift in the rear with the leaf springs. And the generic kit I got was meant for 2-2.5" rear lift.
  11. Aug 1, 2012 at 9:28 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    The only thing that's bad about not raising the BPV is front brakes work harder and wear out faster, probably a safety issue also, save your cash and modify the bracket you already have.
    If the present bracket is for a 2-2.5 lift and your only @ 1 inch lift there's your problem.
  12. Aug 1, 2012 at 9:33 AM
    sirsaechao
    Tim
    Commifornia
    Meh true. I can also sell this one to someone with a larger rear lift.
  13. Aug 1, 2012 at 9:57 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    Ya that bracket is too high.
    My 5 packs only gave me about an inch or inch and a half.
    The BAMF one is great as if you decide to add the wheelers AAL later to the pack..just move the BPV up a few holes.
  14. Aug 1, 2012 at 10:44 AM
    Smokey11
    Smokey11 You Can't Fix Stupid !
    Jeremy
    Anchorage, Ak
    99 ex-cab TRD 2.7L 4X4
    OME 881, 10MM top plate spacer,nitros,wheelers 5 pack, 1.25 Daystar Shackles,265-75-16 Duratracs on 16X8 Pro Comps,leer shell, husky liners, sway bar removed, X-runner badges, tint, auto start, BPV relocate, extended rear brake line.
    Installing the same set up this weekend, do you think you could just drill a hole above the first bolt on the bottom and mount it that way and it should get you close right?
  15. Aug 1, 2012 at 12:24 PM
    sirsaechao
    Tim
    Commifornia
    I haven't gotten a measuring tape to see but it appears the middle solid metal has plenty room to drill two more holes
  16. Aug 1, 2012 at 12:38 PM
    Smokey11
    Jeremy
    Anchorage, Ak
    Well if you get it squared away by Sat morning could you post results please? If not I will just take a stab at it and drill holes in mine until it works !
  17. Aug 1, 2012 at 8:33 PM
    sirsaechao
    Tim
    Commifornia
    Blah don't have a larger drill bit so imma wait for my BPV from BAMF.
