Brake question about brake dust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by keninsb, May 23, 2014.
  1. May 23, 2014 at 6:22 PM
    keninsb
    keninsb [OP] "Senior", Senior Member
    Ken
    Goleta, CA
    '13 Taco DC 4WD V6 LTD
    I installed some EBC slotted and dimpled rotors with some EBD 7000 Series Green Stuff brake pads about 1000 miles ago. Since then I have noticed that the drivers side seems to be "dusting" a lot more than the passenger side. Has anyone ever noticed something like this? Does it mean that I may have some air in one of the lines? The entire system was bled very thoroughly when installed. Any help is greatly appreciated.
    Thanks,
    Ken
  2. May 23, 2014 at 7:34 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Maybe you just brake more often on right hand corners when the driver side tire is moving faster. :p
    You would know if the passenger front brake was full of air. Your pedal would feel mushy and it would pull to the left under braking. Try some 60mph to zero panic stops on a lonely road somewhere. I bet the pads just aren't bedded in properly.
  3. May 23, 2014 at 7:45 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Also there's more weight on your driver side
  4. May 23, 2014 at 7:53 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I'm not an engineer, I've never driven a train, but that doesn't make sense assuming the Tacoma has a rigid chassis.
  5. May 23, 2014 at 8:00 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    first gens had "taco lean." you 2nd gen guys were just screwed before the 2nd gen even came out.
  6. May 23, 2014 at 8:03 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I'm aware the driver side of the vehicle has more weight. That doesn't equate to more work for the brake pads on the heavy side, but like I said, I've never driven a train.
  7. May 23, 2014 at 9:27 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    driver's side wears out more than passenger on brakes, happened with every set I put on, regardless of vehicle.
    now depending on the dust maybe you should have kept the solid discs, unless of course you're racing the Taco :)
  8. May 23, 2014 at 9:33 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I'll be a monkey's uncle. I've never noticed that before.
  9. May 23, 2014 at 10:05 PM
    RND2
    RND2 Well-Known Member
    In my head swimming around
    12 DCSB
    RCD 4"
    What foot r u using to brake with?
  10. May 24, 2014 at 10:40 AM
    Drinknmolson
    Drinknmolson Well-Known Member
    Wheat Ridge, CO
    10 DCSB sport
    LOL
  11. May 24, 2014 at 2:34 PM
    keninsb
    Ken
    Goleta, CA
    Thanks for the replies guys. I am using my RIGHT foot so maybe that is the problem. Should I start alternating :)
    Seriously though, My brakes don't feel mushy at all. I have SS braided brake lines installed and bled the hell out of the system after the new pads, rotors and lines were installed so it is pretty rock solid. No "spongy" feeling. Just seemed weird to me.
    Ken
  12. May 24, 2014 at 9:26 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    rotate tires until all wheels are dusty :notsure:
    seriously, the post above about doing a deliberate stop from 60 or so would be wise to do, just to make sure you don't have something weird going on
  13. May 24, 2014 at 9:29 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    You shouldn't have had to bleed anything. You just remove old rotors and pads, then install new rotors and lube/install new pads.
    :notsure: what you did
    Before i got to 600 miles on my EBC stage five kit, i did the 10 60-10mph stops. It seemed to have really baked the coatings together nicely
  14. May 25, 2014 at 5:10 PM
    Ken08Taco
    Ken08Taco Well-Known Member
    Ken
    Pittsburgh, Pa.
    2008 Tacoma TRD Sport
    Does anyone have an opinion on those Kleen Wheels Dust Shields that you put inside your rims to prevent the dust from getting on your rims?
    https://www.kleenwheels.com/
  15. May 25, 2014 at 6:51 PM
    mdcmn7
    mdcmn7 Well-Known Member
    Chuck
    East Coast
    I just wash my wheels
  16. May 25, 2014 at 7:13 PM
    AR15xAR10
    Once every week or two....so do i
  17. May 27, 2014 at 5:12 PM
    keninsb
    Ken
    Goleta, CA
    Well, the pads and rotors are less than 1000 miles old. I installed EBC Slotted/dimpled rotors and Green Stuff pads and SS brake lines. I followed break-in procedures VERY carefully. I will give the quick stop thing a try, just want to make sure I pass the 1000 mile "break-in" period that EBC recommends before any hard core stops.
    Thanks again guys.
    Ken
  18. May 27, 2014 at 6:10 PM
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    Maybe pull off the wheel, check both pads on that side and make sure they are wearing evenly. These calipers are four piston and different than a lot with slides but I think they can still seize up. Worth checking I'd say.
