Brake question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobg03, Mar 20, 2012.
  1. Mar 20, 2012 at 3:30 AM
    bobg03
    bobg03 [OP] Well-Known Member
    NE Ct
    Tacoma
    Wheels, Bull Bar, Tonneau Cover
    Anyone experience this?
    I have a "11" Tacoma, 5 speed, 4 cyl. It has 15K on it in 6 months, 90% highway miles.
    At times when coming to a stop during the final seconds I hear a squeal, like they are worn out. This does not happen everytime and has happened in both wet and dry conditions. Appears to be coming from the front, but we know how sounds can be deceiving.
    They are not worn, neither are they glazed over....of course it wouldn't do it for the dealer.
    I am a gentle driver, typically I will go 60 to 70K on a new vehicles front brakes even w/an auto, needless to say w/a stick I am on the brakes even less.
    Any ideas?
  2. Mar 21, 2012 at 3:49 AM
    bobg03
    NE Ct
    Tacoma
    Well I'm kind of glad to see that nobody else has this issue, but kind of disapointed cause I'm out of ammo to fight w/the dealer. It just won't make the noise when it's there.
  3. Mar 21, 2012 at 4:00 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I see you are in the northeast... if they use road salt in your area, you will want to get it off, it can cause them to squeak. I would take a hose and spray them off. That has fixed mine from squeaking in the past. Dust can also cause it. Hopefully that will fix it.
  4. Mar 21, 2012 at 6:51 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Has it been doing this since the day you bought it?
    Perhaps the brakes are still 'breaking in' (per say).
    Drive in reverse and do some braking. Or....try doing some POWER Braking - hit the brakes harder a few times....
    Keep in contact with your dealer about the issue. If there is a problem, it'll eventually get worse...and you want this to be under warrantee.
  5. Mar 21, 2012 at 6:55 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Google brake squeal and you'll find lots of stuff. Just try to isolate the one(s) that are making the noise and disassemble and apply a fix. Like grease, shim, etc. And avoid anything that is applied to the rotor or pad surface.
  6. Mar 21, 2012 at 7:03 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Mine squeels every so often in the mornings. Once they've been used a couple times, it goes away. Also happens to me a lot after a wash.
  7. Mar 21, 2012 at 8:57 AM
    myname150
    myname150 Well-Known Member
    Mine do it. Been doing it for a long time even with thick pads still on.
    Mornings too, backing out of the driveway, they squeal a lot.
  8. Mar 21, 2012 at 9:05 AM
    1980 Well-Known Member
    The Dust Bowl
    Ditto for me -- my '06 usually whines a bit in the morning when I back out of the drive and has done so since it was new; it's more noticeable when it's wet (like it is today).
  9. Mar 21, 2012 at 9:24 AM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    Yea, I occasionally get the brake squeal going lower speeds. Oh well, what can you do its a truck.
  10. Mar 21, 2012 at 2:17 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Very common, but not spoken about much on here for some reason. Seems everyone has been doing it from new. I've been playing around with some anti-seize + anti-squeal on mine. It rains a lot here, and I haven't had it squeal since I serviced them last. Even after a salty winter. The contact points aren't properly lubricated from the factory, just well enough for them not to seize, and not quite enough to keep them from squealing. Ask them to service your front brakes. Should cost you $50-$70 depending on dealer.
    -S
  11. Mar 21, 2012 at 7:15 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Anyone ever chamferred the pads? Had it done on my squeaky Corolla and the squeaking stopped.
  12. Mar 21, 2012 at 8:33 PM
    1GR
    Scott
    BC, Canada
    The pads are already chamfered on the trailing and following ends. Don't want to do it too much, otherwise brake performance and rotor wear will be a factor.
  13. Mar 22, 2012 at 6:37 AM
    bobg03
    NE Ct
    Tacoma
    thx for the replys...I'll address them in order.
    1.Road salt, they use calcium chloride here now, (nasty stuff) I rinse the vehicle every couple of days. BUT it has been a mild winter w/very little snow and icy conditions.
    2.Not since new started about 12k (has 15K now) even tho I am easy and downshift a lot I have tried hard braking a couple of times and drove in reverse and tried also to no avail.
    3.There is no regularity to this sometimes wet, sometimes dry....can occur from the first time they are applied OR after driving 75 miles on the MassPike. Just not everytime.
    4. Being a truck is not an acceptable excuse..I am 53 years old and have owned all types of trucks....acceptable brake noise is when they are worn out and need replacing.
    5. I'll ask the dealer about servicing them by lubricating the contact points..as to the $50 to $70 charge, I don't think so. It's under warranty and shouldn't make any noise.
    thx for all the replys....
  14. Mar 22, 2012 at 5:28 PM
    1GR
    Scott
    BC, Canada
    Brakes are not a warrantable component. They will Machine rotors within first year under certain circumstances. The dealer MAY no charge you out of courtesy, but Toyota will more then likely not cover that under warranty. If the dealer tells you they covered it under warranty, it's more likely just them eating the cost, rather then charging Toyota for it.
  15. Mar 25, 2012 at 10:06 AM
    bobg03
    NE Ct
    Tacoma
    That's OK, as long as I'm not paying...
    Update...I was able to let the dealer hear the noise as I happened to be in Mass and stopped to get fuel right around the corner from the dealer and lo and behold there it was.
    Drove right over and as I pulled into the drive up service bay and stopped I asked the advisor to listen....he said wait let's get a tech.
    So the tech that inspected them was able to hear it but could not narrow it down to the front or rear (I don't feel so stupid now...lol) so a case was opened and after we 3 discussed it at length I was advised to be more aggressive on the brakes for a few thousand miles. The theory is that it will either get worse or go away..if it remains and becomes constant they will do whatever it takes to correct this.
    We all agreed tho that a new truck should NOT make brake noise.
    We'll see.....updates to follow
  16. Mar 25, 2012 at 8:05 PM
    huskertacoma
    huskertacoma Member
    Nebraska
    06 SR5,dbl,lngbd,4x4
    The front brakes on my 2006 squeaked primarily when backing out of the garage in the morning. However, on a few occasions, it did squeak when moving forward with the brakes applies very lightly. The dealer replace the following under TSB-BR005-07 on 3/27/09.
    2ea. 43512-04052 rotor disk
    4ea. 77749-35040 clip, pin hold assembly
    1ea. 08887-80609 disk brake caliper grease
    I have 60K on it now and it never squeaks.
  17. Mar 25, 2012 at 11:31 PM
    MotorsportsAustin
    MotorsportsAustin Well-Known Member
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Why didn't they just try putting some Permatex disc brake quiet on the backs of the pads?
  18. Mar 25, 2012 at 11:59 PM
    1GR
    Scott
    BC, Canada
    There are many types of anti seize/anti squeal. I personally use Never-Seez (sp?) at work. Stuff is great.
  19. Mar 26, 2012 at 7:16 AM
    Syncros
    Syncros Well-Known Member
    Never-seez is good for some of the moving parts and contact areas but not the backs of pads. 99% of my Never-Seez use is on threaded parts.
    Stop Squeal works good, its a tacky silicon type product that you apply to the backs of the pads. It dampens the vibrations which cause the noise.
  20. Mar 26, 2012 at 4:06 PM
    bobg03
    NE Ct
    Tacoma
    We're all under the assuption that it is probably the front, but the technician did think that it MAY be coming from the rear.
    We will see.....
