brake question
Discussion in 'Performance and Tuning' started by Lentsnh, Feb 13, 2009.
  1. Feb 13, 2009 at 8:48 PM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    How in the hell do you fix squeaky drum brakes??? When I barely press on the brake pedal (right after you get through the "slack") it squeaks like crazy...
    and while im at it the cabin air filter......if its still ticking could it be the fan being unbalanced
  2. Feb 13, 2009 at 8:51 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    New Bern NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
  3. Feb 13, 2009 at 8:54 PM
    Lentsnh
    Oh yeah i have that thread in my favorites! :D I still dont get it though. the most logical things for the ticking would be the unbalanced fan or the bearings went bad.
  4. Feb 13, 2009 at 8:57 PM
    jolayiv
    Jim
    New Bern NC
    Me either really, but mine only ticks on the lowest setting. So it sounds like i need to loosen one of those screws.
  5. Feb 13, 2009 at 9:10 PM
    Lentsnh
    yeah mine does it on Fresh vent or low to low-mid AC. My dad thinks I'm crazy..... haha hes just deaf! haha (not really)
  6. Feb 13, 2009 at 9:12 PM
    jolayiv
    Jim
    New Bern NC
    haha thats the same thing I tell my wife.
  7. Feb 13, 2009 at 9:21 PM
    Lentsnh
  8. Feb 14, 2009 at 6:39 PM
    Lentsnh
    anyone?
  9. Feb 14, 2009 at 6:42 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    pull the drums and emory cloth the inside of them, spray the shoes with brake cleaner and when they dry emory cloth them too. keep in mind you're not trying to sand off deep grooves, just the glaze on them.
    if that doesn't work have the drums turned and get new shoes. if you do the work yourself it'll probably cost you all of 40 bucks
  10. Feb 14, 2009 at 6:42 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    your shoes may be glazed, you can remove the drum, lightly scuff both brake shoe and drum with sandpaper to get rid of glaze
  11. Feb 14, 2009 at 6:58 PM
    AK27
    AK27 Well-Known Member
    for the cabin air filter..... i had ticking (like a loose washer on a bolt tick), turns out it was exactly that, a loose bolt with a washer! i dont know which one because the dealer took care of it, and i also had a mitt-full of pine needles jammed in the fan blades. dunno if this helps but thats what was wrong with mine
  12. Feb 14, 2009 at 7:01 PM
    Lentsnh
    Thats what i think it is and yeah i got a ton of leaves and what not come out when i pulled the air filter out.
  13. Feb 14, 2009 at 7:03 PM
    Lentsnh
    alright ill try that. Thanks. Rep for you!
    Now for the emory cloth... whats that?
  14. Feb 14, 2009 at 7:03 PM
    Lentsnh
    Rep to you too!
  15. Feb 14, 2009 at 7:04 PM
    AK27
    dig out as many as you can and try a slim extension for a vacuum to get whatever else is still in there. wish i could help with the bolt that has a washer on it but i truly dont know which one it is:confused: or how many have washers in there
  16. Feb 14, 2009 at 7:06 PM
    Lentsnh
    Its on TTROA(?) I think the bolt is on the top of the fan that holds it down. Delphi=:puke:
  17. Feb 14, 2009 at 7:10 PM
    HerNameIsLucy
    RIP Lucy.
    emory cloth is a morons (me) way of saying emery cloth. it's sandpaper, usually very fine, that is cloth backed instead of paper backed so it can be used wet without falling apart. i prefer it over paper backed because it's a lot harder to tear apart, and the actual grit is some different material than the paper stuff uses. just works better for metal IMHO. you can get it at any hardware store pretty cheap.
  18. Feb 14, 2009 at 7:13 PM
    Lentsnh
    ok cool so basically your saying is that my drums are too smooth?
  19. Feb 14, 2009 at 7:20 PM
    HerNameIsLucy
    RIP Lucy.
    Nope, drums (and rotors) get a "glaze" on them. it's friction material from the shoes (pads) that has kind of "baked on" the surface. it reduces braking ability somewhat and can cause squealing and grinding noises. on the shoes / pads it's the same stuff, but decided to stick to the shoe / pad instead. same effect though.
    edit phantom beat me to it...
    2nd edit - it's a good idea to wear a respirator when doing this...you don't need cancer later in life from a simple brake job today!
  20. Feb 14, 2009 at 7:25 PM
    Lentsnh
    Alright I will and yeah ill follow up on what phantom said to GOOGLE it first
