brake rattle?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Apr 3, 2010.
  1. Apr 3, 2010 at 11:56 AM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    Whenever I hit a small bump or crack in the road, there is a rattle that seems to be coming from the front left wheel. The reason why I think it is the brakes is because if I am braking when i hit a bump or crack, I don't hear anything. Any help?
  2. Apr 3, 2010 at 6:42 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Check you caliber and see If your bolts are tight. And also check your lugs. But thats just a off the head geuss. :) I know that I had a small rattle while hitting bumps right after I Installed my lift, but no machanic could find the reason, everything was good and tight and then it slowly went away.
  3. Apr 3, 2010 at 6:46 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    there is a thread on here about the anti rattle springs i believe
