Brake Reservoir, why the difference
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hardground, Mar 29, 2011.
  1. Mar 29, 2011 at 2:12 PM
    hardground
    hardground [OP] Well-Known Member
    Massachusetts
    2011 TRD OR DC V6 Manual
    OME Lift, ImMrYo Mirror Bracket, BlendMount & Mirror Tap ,TRD Quickshifter, 4x4 Illuminated Switch, Red Line Hood Struts, Bak Roll-X
    Check Post #5
    What is the second reservoir for? Damn thing is in my way.
    Does anyone think I can move this further back in the engine bay without having problems?
    Want to do the
    Blue Sea aux fuse block install as seen in both of these posts:
    www.tacomaworld.com/forum/2nd-gen-tacomas/69853-blue-sea-aux-fuse-block-install.html
    www.tacomaworld.com/forum/2nd-gen-tacomas/103200-blue-sea-fuse-block-install.html
    My
    2011 TRD OR DC V6 Manual is the first picture and friends 2007 Base AC V6 Automatic is the second.
  2. Mar 29, 2011 at 2:14 PM
    John3
    John3 Well-Known Member
    Maryland
    Barcelona Red 2010 DCSB TRD Sport
    OME 884X Coil Springs, CS047 Dakar Leaf Springs, 90000 Nitrocharger Sport Front Shocks and N182 Nitrocharger Rear Shocks, Light Racing UCAs, WeatherTech Floor Liners, Leer 100XQ Cap, 3/4" Plywood Carpeted Bed Platform, Thule Rack System w/4 Rocky Mounts PitchFork bike mounts, Pop & Lock PL5300, rcbs204 4x4 Illuminated Switch Mod, Dome Light Mod, Fog Light Mod, FLYZEYE Designs TCMA-0511 V2W LED Light, Go Rhino Dominator II SideSteps, HitchSafe, Console Vault, Fumoto F-103N Oil Drain Valve
    Clutch fluid reservoir
  3. Mar 29, 2011 at 2:17 PM
    hardground
    Massachusetts
    Can I move it back a few inches in the engine bay?
  4. Mar 29, 2011 at 8:51 PM
    hardground
    Massachusetts
    Is it possible to move the clutch fluid reservoir a few inches to make room for a second fuse box?
    And is it "very" important how long the clutch fluid line is?
    More fluid will be in the line if it is longer and know there is a low and high line on the reservoir.
  5. Mar 29, 2011 at 11:08 PM
    jeepmor
    jeepmor Well-Known Member
    Since it's connected mechanically, it's a big job to move and inadvisable. Look at your pedal assembly under the dash and you'll see why. You'll have to work around it. As for the line length to the slave at the clutch fork, not an issue, make it as long as you need.
  6. Mar 29, 2011 at 11:13 PM
    hardground
    Massachusetts
    Thank you, will have to come up with a new design.
  7. Mar 30, 2011 at 1:47 AM
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    The Picture of your truck looks like you have a electrical brake booster rather than the engine vac brake booster, this might because you have a TRD truck which has active traction control mine looks like the second pic and I have a tube going into the brake fluid reservoir that also goes to the clutch master cylinder. I have a 4.0l 6speed too but its only an SR5.
  8. Mar 30, 2011 at 2:20 AM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    Mine looks more like the auto and I've got an 07 manual?
  9. Mar 30, 2011 at 3:31 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    My clutch draws from the brake reservoir. They changed the design again? Was it causing problems?
  10. Mar 30, 2011 at 4:24 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You're far better off redesigning a NEW position for the Aux box.
  11. Mar 30, 2011 at 6:57 PM
    hardground
    Massachusetts
    Looked at it again today and nothing is connected to it but a rubber tube as you can see in this new picture.
    I am talking about about the reservoir on the right. I would never think to move the one on the left, well beyond my skill.
    So maybe I can move this since you said I can make the line as long as I need?
  12. Mar 30, 2011 at 7:31 PM
    hardground
    Massachusetts
    Good point, that is probably why my reservoir is larger. Yours looks like maxamillon's then. What do you have on the top of your passenger side wheel well?
    You are making me think I can move my little reservoir on the right then.
    Why couldn't I just design an Aux Box mount that also has a mount for the clutch fluid reservoir? Again just want to move the reservoir on the right, there is really nothing to it other than a reservoir and a rubber line. After seeing maxamillion's picture, his rubber line goes right into the main reservoir, my rubber line just goes to a second reservoir.
    I was so deflated after opening my hood and seeing the second reservoir in the way but now with the info I am receiving I think this can be done. Thank you all for your help. A custom Aux Box mount with a clutch fluid reservoir mount would be awesome.
  13. Mar 30, 2011 at 7:34 PM
    hardground
    Massachusetts
    Do you know what kind of hose this is? What is the material?
  14. Mar 30, 2011 at 8:05 PM
    hardground
    Massachusetts
    Good advice, will help with the design, thanks.
  15. Mar 30, 2011 at 8:43 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    I stand corrected
    This is why you can't move it though, lots of stuff going on
  16. Mar 30, 2011 at 8:56 PM
    hardground
    Massachusetts
    Funny I can not see your original quote. If wippersnapper02 did not reply to you I would not have known you posted anything. Thanks for the reply.
  17. Mar 30, 2011 at 9:05 PM
    jmg256
    Al Tonter
    TRD Offroad
    Post was removed due to inaccurate info that is in whippers quote
  18. Mar 30, 2011 at 9:27 PM
    hardground
    Massachusetts
    Don't know what you are saying here.
    My manual does not show the clutch reservoir. They need to rewrite this manual so I won't have to bother people.
  19. Mar 30, 2011 at 9:44 PM
    hardground
    Massachusetts
    Got ya now. Hope this does not f up my warranty, either way my warranty will be gone at the end of the year.
  20. Mar 31, 2011 at 12:26 AM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    What do you have on the passenger side? I mounted mine there since it was empty.
