Brake rotor and pad recomendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeshore, Apr 24, 2008.
  1. Oct 2, 2008 at 11:57 AM
    motoyoyo
    motoyoyo Member
    6 lug wheels here.
  2. Oct 2, 2008 at 12:02 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    OK, thanks. I may have to go with Porterfield pads. More money than Hawks, but I hear great things about them.
  3. Oct 2, 2008 at 12:35 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Depends on how a person drives. I swapped mine out at 5k miles because I knew what would happen if I didn't.
  4. Oct 2, 2008 at 7:35 PM
    hate2work
    Washington State
    06 standard cab
    Anybody have a good totorial on changing out the rotors? I did this once about 15 years ago, helping a buddy out, but don't remember the details.
    Thanks~
  5. Oct 2, 2008 at 10:30 PM
    mjp2
    NJ
    Once you pull the wheels I think it's 4 bolts for each side. Remove the caliper, then remove the bracket that holds the caliper in place and the rotor falls off. It's really straight-forward and the bolts are obvious when you're looking for them. Just keep a breaker bar and dead-blow hammer handy -- the caliper bracket bolts are held in place with lock-tight.
  6. Oct 3, 2008 at 6:48 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    bear rotors and hawk pads.
  7. Oct 3, 2008 at 7:20 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I don't think I want to get brake job advice from the guy who's brakes don't work...
  8. Oct 3, 2008 at 8:30 AM
    mjp2
    NJ
    My brakes work great! Look at how effective my truck goes nowhere! ;)
  9. Oct 3, 2008 at 8:32 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    :rofl: I don't want my brakes to work that well!
  10. Feb 19, 2010 at 10:38 AM
    Flugelhornjazz
    Flugelhornjazz '06 4.0L 4x4 6-sp MT Access
    New England
    06' 4.0L 4x4 6sp MT Access
    AFE CAI, all synth fluids, 2.5" exhaust w/ FlowMaster, Optima Deep Cycle battery, Fog mod, SnugTop cap, HID headlights, silicone hoses
    I did something a little different. A few threads said the slotted rotors could be noisy when the brakes are applied so I bought PowerStop drilled rotors and PosiQuiet pads from AutoAnything. I also installed G-Stop SS brake lines...finished with DOT 4 synth brake fluid and moly grease on the spindles when the original rotors came off. With the brake upgrade and new XLT rubber all the way around, this monster will stop on a dime.
    You're right about the shims. If the Hawks have shims glued to the back of the pad, you don't need the stock shims in addition. Any reputable garage will be able to turn the stock rotors. It's worth having them done even if you're not sure the rotors are warped. Shaving 5 or 10 mils will remove the glaze left from the old pads and true both inside & outside surfaces. Your new pads will last longer and grip better too. :cool:
