Brake rotor Change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluesky44, Apr 8, 2016.
  1. Apr 8, 2016 at 4:45 PM
    bluesky44
    bluesky44 [OP] New Member
    Blue
    Plano,Texas
    PreRunner
    I need new brake pads, but when do I need to change my brake rotors, I have 90k miles, I don't feel any warping or anything odd when stopping my tacoma. Thanks
  2. Apr 9, 2016 at 5:14 AM
    jerzeyjoe
    jerzeyjoe Well-Known Member
    New Jersey
    08 Prerunner 2W
    Rotors are cheap. With 90,000 miles I'd just replace them.
  3. Apr 9, 2016 at 5:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    there are specs cast in the edge of the rotor. Use a mic to measure the deepest grooves. That will let you determine the wear status. Anymore it's usually only a few dollars more to buy new rather than mess with turning if they are out of spec.
    Normal rotor wear is about two sets of pads. If the rotor measures well and has no unusual grooving, you can clean them thoroughly with scotch pads and brake cleaner and install the new pads. I would also do a full brake fluid change/bleed and clean/lube/adjust the rears.
    Be sure you properly bed the new pads.
