Brake Rotor Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by muddycoyote, Aug 18, 2017.
  1. Aug 18, 2017 at 6:00 PM
    muddycoyote
    muddycoyote [OP] New Member
    Trevanion
    '00 TRD 2.7 4x4; beat to hell and back
    Everything. Ford f250 leaf springs, old welded cat exhaust, vice grip holding the slave clutch cylinder onto the bell, about half the body covered in truck bed liner...
    Do I have to take the manual locking hub off in order to free the brake rotor on my 2000 4x4 tacoma?
    I can't find a single video of this process with a 1st gen taco. Tons for 2wd, nonw for 4wd. Any direction appreciated.
  2. Aug 18, 2017 at 6:04 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Just take off 1 tire and see if the rotor falls out of place. The wheel and wheel nuts are what usually hold it all together.
  3. Aug 18, 2017 at 7:37 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    No on the hub, you will just have to remove the caliper and possibly the caliper mounting bracket but I'm not sure on the bracket.
  4. Aug 22, 2017 at 9:22 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Remove the wheel, remove the two bolts on the back of the caliper, then the rotor will come right off.
    I have the same setup, 4x4 w/ manual hubs.
    SwampDeer likes this.
  5. Aug 22, 2017 at 10:52 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    What he said...
    You don't need to disconnect the brakeline, and you don't want to let the caliper 'hang' by the brakeline once you remove it. Use something to tie it off to the upper control arm...
  6. Aug 22, 2017 at 11:06 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    I am personally a fan of a bucket. OR use a coat hanger to bend up a bracket to hang it from the control arm or coil.
  7. Aug 22, 2017 at 4:25 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    OP,
    When you remove the caliper, stuff a deep well 11/16th socket into it length wise... between the pads. This will keep the caliper pistons from 'closing in' the pads and make it easier to install once the rotor is on. Remove the socket and quickly slide over the rotor.
    Good luck.
    pray4surf likes this.
  8. Aug 22, 2017 at 5:04 PM
    SwampDeer
    SwampDeer Active Member
    99 Tacoma 4x4
    3 inch lift.
    What he said. Just got done doing mine and this man is100% spot on.
