Brake rotor stuck to hub
Discussion in '2nd Gen. Tacomas (2005-2015)' started by N6Y3H1C, Jun 25, 2021.
  1. Jun 27, 2021 at 11:20 AM
    #61
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Hasn't happen to me in 30+ years. Even Eric from South Coast Auto does it (auto mechanic on youtube, if you haven't heard of him). Maybe some folks are putting too much grease. A light film goes a long way.
    winkel and Too Stroked[QUOTED] like this.
  2. Jun 27, 2021 at 11:54 AM
    #62
    6 gearT444E
    Deep South
    Herculiner Hootus
    high heat anti seize works well. It will not liquify. Good for up to 1800°F
    wi_taco and tacotoe like this.
  3. Jun 27, 2021 at 1:36 PM
    #63
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I will agree that moderation would be a key to success with grease. The one's that failed with grease that I had to fix probably went a little heavy on grease application. On the other hand, I've never had one fail with high temperature anti-seize compound.
    Meanwhile, back to getting the original stuck rotors off ...
  4. Jun 27, 2021 at 7:24 PM
    #64
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    damn, at this point maybe its time to pull the hub off with rusted rotor still attached and have a shop press off the rotors. The worst I've ever had to do was to soak the rotor/stud junction with the good old acetone/atf mixture then apply a blue-tipped ford wrench all around the perimeter followed by a few smacks w/ a 3# ford wrench.
    Best of luck to the OP.
    GREENBIRD56 and tacotoe like this.
  5. Jun 27, 2021 at 8:55 PM
    #65
    Waasheem
    Waasheem
    2007 xrunner
    I tried doing brake job on a pickle factory machine. You think road salt is bad, try vinegar sugar salt wet with pickle juice. Just getting the wheels off, I fought with my 5’ pry bar back and forth for about 30 minutes on each wheel. Then every part was unusable. Springs, levers, backing plate, adjusters all rusted beyond belief. Then the brake line nut was rusted onto the wheel cylinders and wouldn’t come off. Then the other end of the brake line nut wouldn’t come off. Then the bolt that holds the little brake fluid manifold broke off. I finally told them there is no end to it, it could potentially end up being a $7k brake job, and they scrapped it.
    tacotoe and 6 gearT444E like this.
  6. Jul 4, 2021 at 5:41 PM
    #66
    N6Y3H1C
    N6Y3H1C [OP] Member
    Long Island NY
    2014 Tacoma 4cyl 5spd 2wd
    Got them off today and brake job is done! Used the OTC 6980 rotor puller. Worked great. Thanks for the help and input
    jackn7, tacotoe, wi_taco and 3 others like this.
