Brake rotor stuck to hub
Discussion in '1st Gen. Tacomas (1995-2004)' started by kiingme413, May 25, 2023.
  1. May 25, 2023 at 11:41 AM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    That's a totally different rotor and hub design. The 5 lug Tacomas have the rotor bolted to the back of the hub. They are very similar to the pre-taco trucks(pre 95.5) (almost identical if you weren't comparing side by side if I remember correctly)
  2. May 25, 2023 at 1:48 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Sure is good job though!
  3. May 25, 2023 at 1:50 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    And, how did you free it?
  4. May 25, 2023 at 2:06 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah I pull that a part every two years to repack that thrust bearing in there....
    I just pull the hub out and leave the rotor hanging there by the calipher...
    I'm 90% sure your gonna have to find a salvage hub on line...
    shouldnt be that hard to find.....
    and then spring for a decent set of aftermarket rotors....not the cheapest....
    when you put the new one together....use the high temp anti seize made for that.
    and get use to servicing it every two or three years......
    Makes me wonder what the calipers are like......in a pick up .....those are your ass....
    SR-71A likes this.
  5. May 25, 2023 at 2:12 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Man...That is rotten
    cruxofthebisquit and TnShooter like this.
  6. May 25, 2023 at 2:34 PM
    Murd3rd
    I doubt he needs a new hub. Just needs a good stiff wire brush (harbor freight welding area for a very cheap and pretty decently stiff one) and some elbow grease. Then when reassembling FOR SURE coat the area where the hub and rotor are mated with anti-sieze!
    HondaGM likes this.
  7. May 25, 2023 at 3:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    He has to get the rotor off first.
    A wire brush won’t get the rotor off.
    He’s in a predicament, the truck is apart but not “apart”.
    Decisions have to be made. I’d be beating it off, prying it off, heating it off……
    Worst case, he gets a new hub.
    HondaGM and Murd3rd[QUOTED] like this.
  8. May 25, 2023 at 3:38 PM
    Murd3rd
    I gotcha. I was thinking after he got them separated. Fair enough :anonymous:
    HondaGM and TnShooter[QUOTED] like this.
  9. May 25, 2023 at 3:40 PM
    TnShooter
    Deogee
    STOCK
    Yeah, if the rotor comes off without damage , then reuse the hub by all means. But that things is rusted. There may be some unintended damage occur during the process.
  10. May 25, 2023 at 3:44 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Outside of the aforementioned heat, pb blaster, etc... I would get creative, and use the truck itself as a press if possible. Set the rotor on something (2x6s?) to get it's height up close to the frame rail, and then find something else the right size of hub, and put that between the frame rail and hub surface, then lower the jack putting the weight of the truck on it. Heat the rotor with the weight there. If that didn't work, I'd call in a ride and get it to a machine shop, or pick up a new hub.
    HondaGM and Murd3rd like this.
  11. May 25, 2023 at 3:52 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Hey, didn't he get them off already in post 16?
    HondaGM likes this.
  12. May 25, 2023 at 3:54 PM
    Murd3rd
    Nope. That's the hub and rotor stuck together with rust. In order to replace the rotor you have to separate the 2. He took the bolts out (that secure the hub to the rotor) but they are stuck together with rust. One of the factors working against him is that the rotor bore is machined to a pretty tight tolerance. So any rust can make it seem like they are damn near fused together...
    HondaGM, SR-71A and TnShooter like this.
  13. May 25, 2023 at 4:15 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Now I see!! Damn these little phones, pics look much better on my laptop! Thx
    I would just heat up that rotor right on the outer surface that contacts to the Hub, without worrying of overheating and with the replacement rotor near to hand.
    This is the worlds worst scenario; you start off with a simple task, and it turns into the 800 lb. GORILLA!
    Come on OP, did it come off yet?
  14. May 25, 2023 at 5:01 PM
    kiingme413
    kiingme413 [OP] Member
    Well I wanna say thank you for replying everyone! First Tacoma . I feel very welcomed .I tried everything . I did not try the torch tho . I don’t really know how to do that . Those bastards are so rusted together I been researching if they were an assembly together lmao . But anyways no parts at the store and no tacomas in the junkyard. Got new calipers and hubs coming in mail . And wheel bearings basically just all new brakes .
  15. May 25, 2023 at 5:02 PM
    #35
    Murd3rd
    Did you search car-part.com? Some salvage yards will ship...
    HondaGM likes this.
  16. May 25, 2023 at 7:39 PM
    #36
    O'Silver_Taco
    MD
    #36
    HondaGM, Murd3rd and thomasburk like this.
  17. May 26, 2023 at 5:49 AM
    #37
    Murd3rd
    #37
    HondaGM likes this.
  18. May 26, 2023 at 9:40 AM
    #38
    O'Silver_Taco
    MD
    After viewing it, that seller sent me a 10% off offer.......so $45 and 10 to ship......
  19. May 26, 2023 at 9:43 AM
    #39
    O'Silver_Taco
    MD
    If you wanted the other one.....I'd offer em $100 for it.......
    guess in the rust belt you cant have too many hub parts.
    On these parts....I would clean em up and keep a light film of fluid film on them...
    especially the outer rear drums......
    HondaGM and thomasburk like this.
  20. May 26, 2023 at 11:12 AM
    #40
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Bummer- I really wanted to know if using the weight of the truck would shake out.
    Also don't be afraid of heat/torch. Heat is a great motivator to get things done. Considering the rust on those parts, you should for sure get yourself a little bottle torch for future work.
