Brake rotor turning is a waste
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stillwell-Taco, Aug 16, 2018.
  1. Aug 17, 2018 at 10:32 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I wouldn't trust O'Reilly's or AutoZone to turn my rotors. They can't even test a battery correctly.
    Lester Lugnut, VirusCage and wilcam47 like this.
  2. Aug 17, 2018 at 12:21 PM
    Stillwell-Taco
    Stillwell-Taco [OP] Well-Known Member
    06 sr5 trd prerunner
    Exactly! Done with them. I just feel that little bit of a pull sometimes to try and keep what I have instead of just throwing away and replacing. But with brakes I’m over it now.
  3. Aug 17, 2018 at 4:23 PM
    Petrol
    Petrol Well-Known Member
    Central Va.
    Tacoma
    I've never seen a rotor machined on the vehicle. Not sure what the advantage would be to even attempting that. A brake lathe and a front spindle do the same thing in terms of rotating the rotor on a fixed shaft. Sounds like a scam to me.
    As for cost ? That has charged over the years. If the rotors are expensive to start with and only exhibit a slight bit of run out, it is still cheaper to turn them.
    HOWEVER, generally speaking in today's world, it is cheaper to just replace them. Labor costs for turning rotors and the cost of new rotors are getting closer to each other. Considering that you can spend a considerable amount of time turning bad rotors and still end up throwing them away in the end,.... it is often safer economically to just replace them to start with.
    I'm not opposed to turning expensive rotors to remove a slight bit of run out, but badly warped rotors should be discarded immediately and cheap rotors probably shouldn't be turned at all.
    Some rotors are just made from better steel alloy than others and don't warp as easily. So that's another factor.
    For the record, I found the rotors made in Canada were better than the ones made in Mexico.
    Stillwell-Taco[OP] likes this.
  4. Aug 17, 2018 at 4:31 PM
    rheath08
    Russell
    Bakersfield, CA
    @Petrol I have had a car with warped hubs. When I put new rotors on it, I had a vibration when braking that was not there before. So the car had the rotors turned on the vehicle and it had the smoothest braking after wards. Even driving like the teenage asshole I was the vibration never came back. It's not a scam.
    fast5speed likes this.
  5. Aug 17, 2018 at 4:40 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I just experienced the opposite- always bought new rotors and thought I’d give a turn a try, for a change. I’ve been wasting money, will turn from now on.
    Edit:
    To clarify, my turning was done by a highly experienced professional
  6. Aug 17, 2018 at 5:03 PM
    Petrol
    Central Va.
    Tacoma
    How do you know that turning them on a lathe instead of turning them on the vehicle wouldn't produce the SAME result ?
    Not much Control in that experiment.
    If it cost more to turn them on the vehicle as compared to turning them on a lathe, I'm going to stick with my analysis that turning them on the vehicle is a scam. If turning them on the vehicle was the same cost as turning them on a lathe, then I will say that it is just a more complicated method the achieve the same result.
  7. Aug 17, 2018 at 5:36 PM
    rheath08
    Russell
    Bakersfield, CA
    I have experience with turning rotors on the car and off the car on a separate machine. Also first hand experience with warped hubs and having new rotors and rotors turned on the car back to back.
    If you need them turned on the car, it's the only way. New rotors will not work because when you torque down the lug the rotors will match the wrapped hubs.
    It is easier to turn them on the car than take them off and mount them so another machine that is on the other side of the shop.
  8. Aug 17, 2018 at 6:03 PM
    TacosConQueso
    TacosConQueso Well-Known Member
    Brian
    1999 Sierra Beige Tacoma 4x4
    Anytime I have OEM rotors I try to have them turned because I know they are likely better than what I could buy to replace them, and I haven't had any issues with this until recently. This last time I had them turned by Oreilly's and I couldn't even leave the driveway they were so messed up. Took them back and they were too thin to be corrected so they gave me some new rotors (Im sure the cheapest they had) to replace them. Now, 7k miles in I think one of the front rotors overheated and now I get a nice shake once they warm up. Now I don't like the idea of having them turned OR replaced so I haven't decided what Ill do next
  9. Aug 17, 2018 at 6:20 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Does anyone ever feel like paying the service provider to just let YOU use their tools and show long them how to do their job for them?
    I went to Chipotle yesterday and the kids totally botched my burrito. Since I go there weekly at the same location I didn’t raise the issue, but they fucked it up. Similiar to fixing my cars because I don’t trust the competency levels of the mechanics in northern NJ (partially due to pressure to get it fixed even if it’s not fixed environment imposed on the technicians), I’d rather just make the burrito myself...
  10. Aug 17, 2018 at 6:27 PM
    Petrol
    Central Va.
    Tacoma
    If you have warped HUBS, why not just fix that problem ?
    Seriously, turning rotors on the vehicle does the SAME thing as turning them on a lathe. If the hubs are warped and therefore warping the rotors when the rotors are attached to the hubs.......FIX THE DAMN HUBS !
    Let's get down to brass tacks here, the rotor needs to be true for the best performance. If we start chasing our tails trying to fix a chain of problems, we're never going to stop chasing our tails.
    If the hubs are warped - fix the hubs.
    If the rotors are warped - fix the rotors.
    It's not that tough folks.
    I've been playing with vehicles for many, many years. You can use money to accomplish just about anything. Use that money wisely and you will have money left over. It's YOUR choice what to do with your money.
  11. Aug 17, 2018 at 6:37 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I have...back in the mid to late 80s at Honda dealerships. Front end elevated - front tires off and a machine turning the wheels with a "stone" cutter to smooth out the surface. Traditional lathe cutting was forbidden at that time. According to Honda dealers in this era, "stone" lathe was the only way to go; else warped rotors. The thing would spin and spin and...
  12. Aug 17, 2018 at 6:46 PM
    Petrol
    Central Va.
    Tacoma
    and then what?
  13. Aug 17, 2018 at 6:50 PM
    Lester Lugnut
    And when done, the rotors were smooth...at least according to Honda dealers way back when. The process worked out ok as far as I was concerned, but yes, I did seem strange as I had never seen this before.
  14. Aug 17, 2018 at 7:00 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Turning rotors is a 20th century exercise.
  15. Aug 17, 2018 at 7:41 PM
    #35
    rheath08
    Russell
    Bakersfield, CA
    You are right. I'm not trying to argue with you. Just expressing that there are reasons for turning the rotors on the car. It is not a scam by any means.
  16. Aug 17, 2018 at 8:21 PM
    #36
    Petrol
    Central Va.
    Tacoma
    If they try to justify a higher labor rate for that same work,.........it's a scam. sorry.
  17. Aug 17, 2018 at 8:56 PM
    #37
    rheath08
    Russell
    Bakersfield, CA
    I can not speak for other shops. How we quote it is.....
    1.5hr or pads, cleaning and paste
    2.0hr for pads, rotors, cleaning and paste
    2.5 for pads, cleaning, paste and machine 2 rotors
    But that is my dealership.
  18. Aug 18, 2018 at 5:33 AM
    #38
    Petrol
    Central Va.
    Tacoma
    The question would be:
    "What is the labor rate to turn the rotors on a lathe verses the labor rate to turn the rotors on the vehicle? "
  19. Aug 18, 2018 at 7:10 AM
    #39
    Kombi
    Kombi Well-Known Member
    Zack
    08 Tacoma 97 Fjz80 01 Tundra
    I have brand new rotors turned, I have bought rotors for my 80 direct from Toyota and they were warped. so now they all get turned from napa before anything happens.
  20. Aug 18, 2018 at 7:54 AM
    #40
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Do the proper bedding in procedure or you will have issues with your rotors
