brake rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FTB530, May 12, 2014.
  1. May 12, 2014 at 4:37 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    4k on my truck when I bought it. (Demo model) next day it was back in for the drums to be turned. Im at 20k now and I have a pulse again. Push the emergency brake in and it will begin. Dealer drove it and said they cant get it to replicate the same issue. I told them I would bring them a video of them on the lathe at my uncles shop since they cant find a warped drum.
    Once I need new rotors I'm going to give autozone duralast gold rotors a try. 3 year warranty and have a z clad coating so the wont rust but where the pad hits. Once its wore off you will get the surface rust as usual but the hub wont rust. Made of high carbon steel as well.
  2. May 12, 2014 at 4:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Powerslot rotors and Wagner thermoquiet ceramics......ftw. Best combo I've ever used.
  3. May 12, 2014 at 5:03 PM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    my oem discs had 135,00 when I changed pads.they weren"t warped but had some heat cracks on the outer edges.i'm still running them.i drive a lot of highway miles though.
  4. May 13, 2014 at 2:32 PM
    FTB530
    FTB530 [OP] Well-Known Member
    Yuba City Ca.
    2005 toyota tacoma
    level kit,air raid intake,
  5. May 13, 2014 at 3:59 PM
    FTB530
    Yuba City Ca.
    2005 toyota tacoma
    Has anyone use the power stop K-1 37 – 36 rotor kit on a Tacoma? Pros or cons if you use them thank you
  6. May 15, 2014 at 7:18 AM
    FTB530
    Yuba City Ca.
    2005 toyota tacoma
    Anyone?
  7. May 15, 2014 at 7:21 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I need to replace my pads and rotors as well...i'll be going with OEM... no reason to go with anything else. The stopping power and longevity is there. :cool:
  8. May 15, 2014 at 7:35 AM
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
  9. May 15, 2014 at 9:09 AM
    FTB530
    Yuba City Ca.
    2005 toyota tacoma
    Price is a good reason!!!!
  10. May 15, 2014 at 9:38 AM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Contact Nathan at Dahl Toyota. He is very good with prices - for example, I got a set of pads for $45, shipped. Also 10 oil filters (including gaskets) for $40, shipped. Also spark plugs, etc...
    Here is their ebay site - just contact him. Most of the stuff I get isn't listed on the ebay site, I just asked... Hope that helps.
    http://stores.ebay.com/dahltoyota/
  11. May 23, 2014 at 12:58 PM
    mr2crazed
    mr2crazed Well-Known Member
    Paso Robles, CA.
    06 DC PreRunner SR5
    What's the proper torque setting for the lug nuts?
  12. May 23, 2014 at 2:21 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    83 ft/lbs on a 6 lug...
  13. May 29, 2014 at 9:53 AM
    celec
    celec Well-Known Member
    Miami, FL
    2013 TRD Sport MGM
    My original rotors warped at 22K, pads look like new... Dealer fixed it for free after I ranted a little bit and caught them trying to say I needed new brake pads.
  14. May 29, 2014 at 9:56 AM
    AlanLoshbaugh
    Alan
    Columbia, MO
    Probably a good time for all of us to check wheel to rotor torque.....
  15. Sep 12, 2014 at 1:03 PM
    #35
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Alright here is the dumb question of the day. Who exactly makes the OEM rotors and pads? I have a 2011 2.7 4wd tacoma and I am not sure what the OEM parts were. I just had my inspection done at 67,000 miles and my brakes passed but the guy advised me to fix them before winter. I went ahead and got them fixed today new rotors and pads for 260.00. I thought this was expensive so I called the dealer and they wanted 400.00 so I went with that guy. He used model ZD976 for the pads Appear to be wagner ceramic. And for the rotors AX31327 that I apparently cant find a manufacturer for. Just wonder if I have really shitty brakes and rotors that I will be replacing in 20,000 miles or what.
  16. Sep 14, 2014 at 10:59 AM
    #36
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    I can't say much about the Wagner pads, I have never used them. I have heard that they are a quality pad. The brake rotors you listed are an Auto Xtra part number. They are sold by Parts Plus auto parts stores. We use them in the garage where I work. We never get complaints about them warping or any other problems. Also wanted to let you know that when you take a vehicle to a dealer for a brakejob, if they don't have the parts in stock you get pads and rotors from a local parts store.
  17. Sep 14, 2014 at 12:56 PM
    #37
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Well thanks Hugh I appreciate the info!
