Brake shudder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scotsman, May 28, 2014.
  1. May 28, 2014 at 3:06 PM
    Scotsman
    Scotsman [OP] Member
    My 2013 ( July ) Tacoma, 6350 miles, been of the road since December through illness, was left with park brake off, when I drive it now I get a brake shudder through the steering wheel. Any ideas and would repair be under warranty or chargeable? thanks
  2. May 28, 2014 at 3:08 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    With that few miles and not even a year old I would take it to your dealer.
  3. May 28, 2014 at 3:10 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    If it's a bad shudder through the steering wheel probably a stuck caliper. Pump the brakes real hard and see if it unsticks. Mine did this once after wheelin. If it doesn't work head to the dealer
  4. Jun 19, 2014 at 11:49 AM
    elmerew
    elmerew Active Member
    Elmer
    San Diego/North Lake Tahoe
    2013 Tacoma DCSB Baja White
    BakFlip F1 Bed Cover, Pop Lock for tailgate, Weathertech Digi Fit Floor mats and Side Window Deflectors, Dash Cover, Custom Seat Covers, Hood Protector, Scanguage 2, TopLine Bed Expander, and Rear seat cover for dog, lots of LED lights (from Chris)
    Just got my 2013 Tacoma TX Baja back from the dealer with new rotors and pads on the front. They have no idea why the rotors and pads failed at just 21,000 miles. I'm very light on the brakes and spend most of my time on freeways. I usually get 100k miles on brakes. The good new is the warranty covers the repair.
  5. Jun 19, 2014 at 2:47 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Rotors on the 2nd gens warp very easily. I've been through 3 sets now.
    Also a good alignment is key. Sitting since December may have caused minor flats in your tires as well, so that may take some driving time to break back in.
    Every time I get the brake shudder, it's either warped rotors or my alignment isn't within spec.
  6. Jun 19, 2014 at 2:54 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Had it happen twice to me, but I'm lifted. Because my alignment was off, my vibes were enhanced during braking. Speaking from experience.
    The truck in question is so new though. But, there are only a small handful of things that could cause the braking shudder.
  7. Jun 19, 2014 at 3:41 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    My stock rotors warped with 25k miles. Then the Brembo blanks warped in 5k miles (could being made in Brazil be the problem?)
    So I just changed my rotors again to Advics high carbon made in USA. Let's see how long they last. It's silly how my truck only has 35k miles and been through 3 sets of rotors.
  8. Jun 20, 2014 at 3:37 AM
    Scotsman
    Thanks to all for replies, dealer machined rotors and truck is fine now.
  9. Jun 20, 2014 at 1:04 PM
    clcartwr
    clcartwr Member
    Mine is doing the same thing at 6k miles....dealer has replaced all brake components and the shudder is still there. They have pretty much told me it is "normal" and won't do any more troubleshooting. Mine was bad enough the hood came unlatched from it once. I'm at a loss as to what to do next.
  10. Jun 20, 2014 at 1:06 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Interesting... Mine just started. I need to get it in. I have 46k on it now so probably due.
  11. Jul 18, 2014 at 5:49 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    HELL YA...!!!!
    Dump that f'n Stealership...!!!
