Brake Squeal???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scottj, Aug 1, 2010.
  1. Aug 1, 2010 at 4:11 PM
    scottj
    scottj [OP] Well-Known Member
    York, PA
    12 DCSB TRD sport OME
    Just had 6 inch pro comp intalled on 07 Access Cab 4x4 yesterday. I'm getting an extremely loud squeal off and on from what I think is the brake slightly dragging. Any ideas what has caused this???
    It goes back to installer tomorrow
  2. Aug 1, 2010 at 5:07 PM
    scottj
    York, PA
    just went out and did some more checking. its acturally the front brakes that are squealing. Its happening even when the brakes are not applied.
  3. Aug 1, 2010 at 5:32 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    check and make sure there is nothing between the rotor and the dust shield....or the dust shield itself rubbing on it. i had a ridiculous squeal when some rocks got caught between the rotor and brake shield.
  4. Aug 1, 2010 at 7:07 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If no debris, clean everything the pad touches and reapply anti-squeal compound to the back of the pad and guides.
  5. Aug 5, 2010 at 5:31 PM
    scottj
    York, PA
    Figured it out. dust shields were hitting rotors after lift. trimmed em down and everything ok
  6. Aug 5, 2010 at 5:36 PM
    The_Hodge
    SC
    BAM!!! lol...good you found it.
