Brake system eating rotors...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bu11etWhisperer, Jul 7, 2021.
  1. Jul 7, 2021 at 11:21 AM
    Bu11etWhisperer
    Bu11etWhisperer [OP] My Taco is Blue!!!
    Mark
    Douglasville, GA
    2010 Prerunner, SR5, TRD Sport, Speedway Blue
    2010 Tacoma PreRunner 4.0L
    So back in Jan, 16' I rear ended a lady (slight bump). It was a slight bump because the brakes worked like a champ when I STOOD on them. However, after the accident, I was on the way home and the front brakes got so hot the calipers were glowing. So, I had the truck towed the rest of the way home. I took it too the dealer and they seen no damage to the brake system and couldn't duplicate the brakes applying. But the system kept ruining rotors. I would replace them about every 6 months. Didn't drive far to work so the vibrating while stopping wasn't too nerve racking until it was. Fast forward to about 4 months ago, I took the truck to Toyota and the whole brake system was replaced. Rotors, Pads, drums, pads, brake booster and calipers (they said one was froze up). Even the ABS box has been replaced. There are no check engine lights, no abs lights or anything else indicating there is an issue with the brake system, except, I believe the pads stay slightly compressed in order to heat up the rotors and in turn cause the horrible vibration while stopping. Has anyone else experienced this? Do you guys know of something I'm missing? Something the dealer is missing? TIA to all help given.
    uurx likes this.
  2. Jul 7, 2021 at 11:25 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    stop resting your left foot on the left pedal while driving :duh:
  3. Jul 7, 2021 at 11:26 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Did they replace the hoses? Quite often the problem.
    Dm93 and TnShooter like this.
  4. Jul 7, 2021 at 11:31 AM
    manncura
    manncura Well-Known Member
    2020 DCSB 6MT Sport
    Different gen, but there was a recent thread in3rd gen where a guy was eating up rotors every 5-10k,,,ended up being a bent axle. Dealer kept checking, nothing wrong until the OP told them to check axle and indeed it was bent. ???
    EDit; here's link
    https://www.tacomaworld.com/threads...inally-discovered.725871/page-5#post-25906936
    BassAckwards likes this.
  5. Jul 7, 2021 at 11:50 AM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    I’ve been having problems with my front rotors warping also after 10-15k miles. New Toyota rotors and trd pads. I’m pretty easy on the brakes for the most part and use the motor compression to slow down as much as possible.
  6. Jul 7, 2021 at 11:53 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Change hoses. Maybe upgrade to braided stainless while your at it?
  7. Jul 7, 2021 at 1:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You said the whole brake system, but didn’t mention calipers.
    Where they replaced? Does the truck pull any direction while on or off the brakes?
    It would be nice to have a look at the pads to see any irregular wear patterns.
    Has anyone ever properly bedded the pads to the rotors?
    The shaking while braking is pretty indicative of pads material transfer/build up on the rotors.
    blu92in99 likes this.
  8. Jul 7, 2021 at 1:24 PM
    Bu11etWhisperer
    Mark
    Douglasville, GA
    Yes the calipers were replaced, op updated.
    TnShooter[QUOTED] likes this.
  9. Jul 7, 2021 at 1:25 PM
    Bu11etWhisperer
    Mark
    Douglasville, GA
    You feel good about yourself now?
  10. Jul 7, 2021 at 1:29 PM
    TnShooter
    Deogee
    STOCK
    While I’ve never seen it. I have heard that bad brake lines and hoses can cause the caliper to stick.
    If it were me, I’d drive the truck. Let the brakes warm up. Then jack up the front end and spin the wheels. See if one or both are dragging.
  11. Jul 7, 2021 at 1:34 PM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    Does the brake booster include the reservior and all of the associated internal valving in the master cylinder?
    Is the brake pedal linkage adjusted appropriately? i.e., does it allow the brakes to be fully released to the point the remaining pressure is dumped to the reservior?
    TnShooter likes this.
  12. Jul 7, 2021 at 1:57 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lift the truck up in the air and spin the wheels, see if one is dragging
    Years ago on a Toyota Sienna the customer did a panic stop on the freeway, his brakes were dragging continuously afterwards. In a hurry to get on the brake pedal (and avoid a collision) his boot actually bent the brake light switch bracket and pushed it forward. The bent bracket was holding the brake pedal arm slightly forward and causing the brakes to drag
  13. Jul 7, 2021 at 2:09 PM
    Strostkovy
    Alex
    White 98 Tacoma
    As my throwout bearing was slowly going out I ended up bending the linkage to my master cylinder, causing binding even after replacing my clutch and bearings. I think I went through three master cylinders on that job.
    b_r_o[QUOTED] likes this.
  14. Jul 7, 2021 at 2:31 PM
    uurx
    '12 t|x pro
    a little :jerkoff: goes a long way mark :blahblah:
    lets see those glowing rotors
    :worthless:
  15. Jul 7, 2021 at 3:30 PM
    Bu11etWhisperer
    Mark
    Douglasville, GA
    Well I guess not every piece. I didn't think that hoses would be an issue if they weren't leaking.
  16. Jul 7, 2021 at 3:37 PM
    Bu11etWhisperer
    Mark
    Douglasville, GA
    Yes, the master cylinder was replaced but I'm not sure about the linkage. Thanks for the idea.
  17. Jul 7, 2021 at 3:40 PM
    Bu11etWhisperer
    Mark
    Douglasville, GA
    Wow, I'm gonna check this. It makes sense, because I stood on them brakes hard! Thank you for the idea
  18. Jul 7, 2021 at 3:56 PM
    Bu11etWhisperer
    Mark
    Douglasville, GA
    Would that not make the brake lights stay on?
  19. Jul 7, 2021 at 4:24 PM
    wrightme43
    Ok based on what you are experiencing, something is holding the brakes on against the rotors.
    Disc brake design ever so slightly wants the pads to pull just barely away from the rotors.
    If you are not applying hydraulic force, the system is either applying hydraulic OR mechanical force to hold the pads in contact with the rotors, or they installed crap parts or they are lying about the wear.
    It is very difficult to answer on the internet.
    Hoses are a common culprit.
    Calipers are a common culprit.
    Most shops install rebuilt calipers.
    New means new it does not mean it is any good.
    The same goes for rebuilt, with the added knowledge that it was removed from service because it failed, then rebuilt. In no way does it mean it is a known functional quality part.
    Find a actual mechanic usually grey headed with a ASE Master Tech patch.. Tip him 20 bucks and talk to him. Ask him if you can request him to work on your vehicle. Tell him whats going on.
    Yeah I know it sexist. blah blah blah.
    There are good female mechanics out there.
    Bu11etWhisperer[OP] and Dm93 like this.
  20. Jul 7, 2021 at 4:44 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The switch plunger has to extend to turn the lights on. The switch itself was what was holding the pedal slightly forward, because the bracket it was mounted on was bent forward
    Just something to check.. it jumped to mind because you mentioned a panic stop situation and I remembered my cust from a while back
