Brake upgrade questions? (2nd gen)
Discussion in 'Performance and Tuning' started by hybrid12micah, Sep 16, 2014.
  1. Sep 16, 2014 at 10:19 AM
    hybrid12micah
    hybrid12micah [OP] Well-Known Member
    socal
    21' Pro DCSB
    I just bought the TRD 16'' wheels for my 2012 and im going to be putting tires on soon but have no purchased them. The rims havent even shipped yet!
    Im looking to to see what i could do to improve braking power? The TRD BBK kit is super expensive, and now states a min-17'' rim is required?! Not sure if it even fit the 2nd gen.
    Next, the tundra brake upgrade seems to only work for 1st gen tacomas.
    Im starting to wonder if i should return my 16'' rims for 17'' or if maybe just pads/rotor upgrade is enough?
  2. Sep 16, 2014 at 10:24 AM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    A pad and rotor upgrade with steel braided lines will make a pretty good improvement. That's what I did and I could tell the difference right away.
  3. Sep 16, 2014 at 10:26 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Few good comments about EBC stage kit. The stage 5 seems to be the most appreciated. Abit more expensive but way cheaper then the big brake kit you're talking about.
  4. Sep 16, 2014 at 10:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yours already has the 4 piston front brakes. So like Glueman stated. That would be simplest way.
    The TRD BBK is very nice. You will have to upgrade the wheels though. It will come with stainless lines as well.
    Just make sure to use a good quality DOT 4, as it will have a higher boiling point than DOT 3's. Which Wil help you if you have any extended braking periods.
    Motul 660 is a very good one. As well as the Castrol. Just can't remember the Castrol's specific name.
  5. Sep 16, 2014 at 6:21 PM
    hybrid12micah
    socal
    21' Pro DCSB
  6. Sep 17, 2014 at 7:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Definitely. For most people that upgrade is more than sufficient. Luckily our trucks already came with 4 piston calipers, unlike the X-Runner (a "sports" truck) which only has 1 piston calipers. For them, the BBK is a worthy/necessary upgrade.
    Now if only our trucks came with rear disk brakes, like the 4Runner, then we'd have a nice setup. Heck, with half the mods people install on their trucks, they out weigh the T4R in no time.
    At least they are convertible to ours....
  7. Sep 17, 2014 at 8:52 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    stage 5, ss lines, a FLUSH (once u boil it, u get air in the lines), and u should be happy
  8. Sep 17, 2014 at 8:56 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  9. Sep 17, 2014 at 8:58 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    drilled have a tendency to crack
  10. Sep 17, 2014 at 9:34 AM
    yota243
    E.J.
    north Alabama
  11. Sep 17, 2014 at 11:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    True, but let me elaborate. All rotors can crack depending on the type of usage. Drilled rotors are more prevalent to those cracks, primarily because of the cheap quality ones. They crack sooner under less stressful conditions than top quality drilled rotors. When those cracks reach 3mm's then they need to be replaced. Had a friend get some drilled rotors. They were some black looking color. I cannot remember exactly ehich brand they were. They cracked after only a few months of street driving. Junk.
    Unless a buyer is ready to pay good money for drilled rotors, and I know that most arent, it is best to stick with slotted.
    Case in point, my drilled Stop Tech rotors cost me ~$740 for the pair. I've raced on them. Multiple times. Not one crack. Yet. In time, they will. Just like any other rotor which sees such extreme heat cycles. Those are as expensive as I want to go, and that isn't even as expensive as they get. :eek:
    Centric are Chinese. If you get those, get nothing more than their slotted. That's just my opinion though. Lucario Runner has had good fortune with their solid rotors on his 4Runner, which he races as well.
  12. Sep 17, 2014 at 11:51 AM
    yota243
    E.J.
    north Alabama
    u would do centric slotted over the powerstop blanks for the same money? or u were saying definately dont get centric drilled and if u were going to get centric dont go more than slotted?
  13. Sep 17, 2014 at 1:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That I wouldn't get any drilled rotor unless it is from a well known, reputable company who has been making drilled rotors for high end vehicles.
  14. Sep 17, 2014 at 4:15 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Powerstop is cheap chinese junk, I have a set on my rav4 and they need to be replaced and look pretty weathered for something that is barley two years old. Power slot, now just called stoptech is much better quality (also chinese but better qc). I have a set on my 4Runner, which see's heavy track use, and my F250 which I use in auto cross as much as possible. I use all three alot so I would also add they are daily drivers. The 4runners brake set up is slotted front rotors (stoptech/power slot) rear centric blanks, TRD pads, stainless steel brake lines, motul 660. I feel very confident with the current set up and would recommend it if going for a big brake kit is outta budget or out the question do to wheel/tire choice.
  15. Sep 18, 2014 at 8:01 AM
    yota243
    E.J.
    north Alabama
    alright i realize i have gone far from the upgrade premise of the OP, but there seems to be a vast knowlege of brakes that are subscibed to this thread so ill ask again, http://www.am-autoparts.com/Toyota/Tacoma/brake-pad-and-rotor-kits/AM-16908589/555709.html i cant find anything on this brand but it has a 10 year warrenty. im not really looking for an upgrade but obviously if there price was about the same i would go for the better product. im simply looking for replacement options and the best bang for my buck right now. so would this be something that would be worth a shot for under $100
  16. Sep 18, 2014 at 9:45 AM
    pavemobile
    pavemobile Well-Known Member
    Wichita Falls, Texas
    2009 TRD Sport SR5 PreRunner
    K&N Intake
    I have had a set of EBC's dimpled and slotted (GD Series) rotors and their 7000 series Greenstuff pads on for a a little over 4 years and other than Bilstein 5100 shocks, that was the best upgrade I have done to my PreRunner. No fade, dust is almost nonexistent, rotors are showing almost no wear. Price for the rotor and pads was not too bad either for the return on investment. Give them a look, try Amazon or Placeforbrakes.com
  17. Sep 18, 2014 at 9:49 AM
    teamcurtis
    teamcurtis Well-Known Member
    Curtis
    San Diego
    2015 DC 4x4 Super white
    285/75/16, snugtop xtravision, pop-lock
    There is a lot of variety in what makes a braking system "better"
    Knowing what your doing with the truck could help the braking experts lead you into the best decision.
    IE towing? Mountain driving? Racing? Just want to come to a stop faster?
  18. Sep 19, 2014 at 9:34 PM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    I think the black rotors you are referring to are the EBC sport rotors, just an FYI for everyone. Sorry if I'm wrong I just happened to notice that.
  19. Sep 20, 2014 at 11:38 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Ebc sports are not drilled
    Dimpled and slotted.
