Brake upgrade recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TA 4, Aug 24, 2019.
  1. Aug 24, 2019 at 2:38 PM
    TA 4
    TA 4 [OP] Well-Known Member
    Ontario, Canada
    2015 SSM Taco access 4x4 2.7
    Cruisin offroad bumper, RCI front skid, Bakflip Tonneau Cover, Westin Running Boards, door molding, Blazer Led lights, Bed Lights, DIY Bed/rear cab mats, 3M Clear Bra (Hood and Fenders), Husky front floor mats, re diff relocated, Coverking seat covers
    Afternoon everyone,
    Just gave my Taco some tlc, had a little pulsing and shaking in the wheel while braking. Long story short like many have said here, the calliper pins had rusted in place fairly badly causing the pads to get hung up. With new pins and all the small parts replaced and lubed the Taco brakes perfectly once again :)
    Now onto he question of this post, does anyone know of Calliper upgrades that have the pins protected or at least a better design. Foreseeing there may be a brake job soon too seeing the rusted state of the callipers....dang Canadian salted roads.
    May have to incorporate a calliper pin lubrication job with every oil change to try to avoid the issue in the future. Plus side though Im just hitting 97,000km and still have +55% of the pads left, major plus to having the 5spd :D
    Cheers
  2. Aug 24, 2019 at 2:40 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Adding it to routine maintenance really isn't a bad idea. If you do a tire rotation with each oil change, greasing the pins would be fairly quick since the tire is already off.
    TA 4[QUOTED][OP] likes this.
  3. Aug 24, 2019 at 3:37 PM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    Hear they make great brake pads with leading edge technology.
  4. Aug 24, 2019 at 8:58 PM
    TacoTuesday1
    SD CA
    Haven't seen the slide pin design yet; I guess there's no rubber boot
    I wonder if a high quality grease can help; there's many choices out there.
    Am surprised a simple pin greasing fixed it, rather than removing the rotors to have them turned on a lathe (if there's even enough meat left in the metal to meet thickness spec)
  5. Aug 25, 2019 at 8:21 AM
    TA 4
    Ontario, Canada
    The grease that Im trying to use now is a die-electric synthetic brake grease. Time will tell how well it works with regular maintenance check ins/pin lubing.
    I didn’t just lube the pins, but as stated above I replaced them completely. I also took the dremel sander to the rust on the pad contact spots in the calliper. All that combine has resulted in free pad movement.
