Brake Upgrade: StopTech Rotors + TRD Performance Pads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Dec 12, 2017.
  1. Mar 9, 2019 at 9:00 PM
    #201
    klif01
    klif01 Well-Known Member
    Or the doggo, she likes dogs more than children.
    Biscuits likes this.
  2. Mar 9, 2019 at 9:06 PM
    #202
    E.RDZ_TACOMA
    E.RDZ_TACOMA Well-Known Member
    Denton, TX
    2007 Blue Tacoma Access Cab 4×4
    Didnt realize you made all those threads:boom:
    Baught some TRD brakes thanks to your recommendation. Waiting for them patiently.
  3. Mar 9, 2019 at 9:06 PM
    #203
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Dogs leave way more money for Taco mods than children.
  4. Mar 9, 2019 at 9:10 PM
    #204
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  5. Mar 9, 2019 at 9:12 PM
    #205
    E.RDZ_TACOMA
    Denton, TX
  6. Mar 10, 2019 at 8:29 AM
    #206
    centurion
    centurion Well-Known Member
    Northern New Jersey
    2006 Tacoma TRD Sport,double cab, 4X4, auto, speedway blue
    Air-Raid air filter, de-badged,custom grill,hood and tailgate struts
    Great write up, thanks for your expertise! You know I'm a little shocked that the 3rd gens don't have disc in the rear, why do you think toyota omitted them?
    crashnburn80[OP] likes this.
  7. Mar 10, 2019 at 8:54 AM
    #207
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Toyota did get flamed for it, and it was certainly a lack of feature that the Colorado/Canyon pounced on. Realistically in an unloaded pickup there is so little weight over the rear end that the fronts do a heavy majority of the braking, but even so rear discs would help some, especially when towing or with a load in the rear. With a rear disc setup you usually need an auxiliary drum brake for the cable actuated parking brake, making it more expensive to produce since you are putting 2 sets of brakes on the rear. It was likely nothing more than a cost savings move. And since Toyota dominates the mid-size market, cheaping out on the rear brakes doesn’t really hurt their sales as people will buy the trucks anyway.
    Beretta4x4 likes this.
  8. Mar 16, 2019 at 6:44 PM
    #208
    Taco'09
    Taco'09 Well-Known Member
    @crashnburn80
    You may have addressed this and I missed it but it is my understanding that all friction materials are require to have a DOT rating marked on their sides using two letters indicating their coefficient of friction (cF) for cold and hot performance. Just curious as to what the TRD performance pads show and whether they have a higher cF (cold or hot or both) than the regular factory pads?
  9. Mar 16, 2019 at 10:45 PM
    #209
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If pads were required to stamp the cF on the side that is news to me. I did not look to compare any side markings, so I cannot say. But I’ll defin look next change out.
  10. Mar 16, 2019 at 10:53 PM
    #210
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    My old Range Rover Classic has a drum brake on the output of the transfer case for the parking brake. Every other vehicle I’ve owned with rear discs has just had a standard cable actuated parking brake utilizing the normal rear brakes. I don’t think that’s an excuse Toyota can use, they’re just doing as few changes and development as possible to maximize profits.
  11. Mar 16, 2019 at 11:24 PM
    #211
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I did drilled and slotted with stoptech street pads. Seems to be a decent upgrade so far over my previous two EBC kits
  12. Mar 17, 2019 at 6:56 AM
    #212
    grlnbear04
    grlnbear04 Well-Known Member
    2015 Tacoma TRD Sport Blue Robbon Metallic
    Those rotors look good, where did you get them??
    AR15xAR10 likes this.
  13. Mar 17, 2019 at 2:32 PM
    #213
    AR15xAR10
  14. Mar 31, 2019 at 5:29 PM
    #214
    Globaldriver63
    Globaldriver63 Well-Known Member
    David
    Upstate SC
    Dude, Super write up, way to go!!
  15. Apr 2, 2019 at 10:00 PM
    #215
    DangerNut
    DangerNut Active Member
    NorCal
    2015 White DCSB TRDOR
    Seems Amazon only has the Right rotors in stock, no left rotors for now. Once they do, looking to pull the trigger on this setup. Thanks for the write-up!
  16. Apr 4, 2019 at 1:08 PM
    #216
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    What about the rear drum set up?
  17. Apr 4, 2019 at 1:27 PM
    #217
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    There are some disc brake conversions, but they also need the master cylinder to be replaced with a larger unit. Many conversions will also not support a parking brake. If you replace the master cylinder on the later model Off Road/Pro trucks, you lose ATRAC.
    Norton likes this.
  18. Apr 4, 2019 at 2:18 PM
    #218
    Freeheelbillie
    Billie
    Saint Clair, MI
    I am fine with a drum. Any recommendations for pad/drum combos?
  19. Apr 4, 2019 at 3:18 PM
    #219
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Stock. There are no performance drum/shoe products I am aware of for the Tacoma. So staying OEM is best for best quality.
  20. Apr 4, 2019 at 3:30 PM
    #220
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    LOL. Brembo does make aluminum steel hybrid drums where the drum housing face is aluminum and the braking surface cast iron, similar concept to StopTechs Areo rotor for weight reduction. But they don’t make it for the Tacoma.
