Brake Upgrade: StopTech Rotors + TRD Performance Pads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Dec 12, 2017.
  1. Jul 14, 2019 at 10:16 PM
    #421
    alexplb
    alexplb Well-Known Member
    It got the new suspenssion lift so yaw sensor reset is most likely the problem. Just shocked shop didn’t recalibrate it. Assuming it’s not related to master cylinder they supposedly replaced. I’m tempted to try the old school battery disconnect lol but that’s a fools arron most likely.
  2. Jul 14, 2019 at 10:18 PM
    #422
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    What was your tire size change?
    PreTaco170 likes this.
  3. Jul 14, 2019 at 11:05 PM
    #423
    alexplb
    Not much I ran 33.5 before now 33.9 285/75/17.
  4. Jul 15, 2019 at 5:02 AM
    #424
    skyking3
    skyking3 Well-Known Member
    Tom
    2025 Tacoma TRD Sport Hybrid
    TRD billet oil cap, Weathertech tonneau cover, Greenland sliders---All following mods were for my 3rd gen --TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    No, I kept the same master cylinder with no problems. The Wilwood kit is actually made for the 2nd gen trucks but I noticed that Toyota did not change any of the front brake parts going from the 2nd gen to the 3rd gens trucks. All of the part numbers are exactly the same.
  5. Jul 15, 2019 at 8:04 AM
    #425
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Did you do the sensor calibration before? Typically this starts to become an issue around the 33+” size. If you managed to not do it before you were likely right on the edge and the slightly larger size put you over.
    alexplb[QUOTED] likes this.
  6. Jul 15, 2019 at 11:02 AM
    #426
    alexplb
    You mean the yaw sensor ? He says they did it but I have a sneaky feeling they didn’t.
  7. Jul 18, 2019 at 5:01 PM
    #427
    alexplb
    New issue ! I’m in a role here omg. So rear Rt brake drum now is jamming. It’s appling the brake to it for some reason gets crazy hot compared to lt side. Reset the yaw and drove a bit and it’s chirping the stability control light on turns. I’m loosing it here.
  8. Jul 18, 2019 at 5:10 PM
    #428
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Eeeek. Did you relocate the ebrake cable for more slack? Only think I can think of maybe it got yanked.
    Saw you ripping through those whoops on IG. That camper was taking it! Reinforce those beds it’s your haven’t.
  9. Jul 18, 2019 at 5:31 PM
    #429
    alexplb
    Oh yeah it was done with tc brackets. Paid a shop to take out the drum and adjust the pads down a bit since wheel was litteraly not spinning by hand. But still it’s getting hot so it’s probably still being messed with by stability control. I hate electionics.
  10. Jul 18, 2019 at 6:54 PM
    #430
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Did you remove the ebrake line mount off the leaf spring is what Meso was referring to. There may be inadequate slack in the line if you dont.
  11. Jul 18, 2019 at 7:20 PM
    #431
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    @BigMike had problems with his drum brakes, he had to weld the two bottom pins , that the shoes rest against, to the backing plates. You might want to check and see if they are loose.
    BigMike and alexplb[QUOTED] like this.
  12. Jul 19, 2019 at 9:34 AM
    #432
    alexplb
    No it’s attached is it ok to let it hang loose thought ?
  13. Jul 19, 2019 at 9:47 AM
    #433
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes, unbolt the brake line mount and ziptie it to the next forward mount under the cab.
  14. Jul 26, 2019 at 7:20 PM
    #434
    Jakoda
    Jakoda beep boop
    Jackson
    SoCal
    2017 TRDOR DCSB
    Bunch O Shit
    Would you be able to take a picture of where you are referring to? I think I have a similar problem where my brake lines are rubbing on my leaf
    Also great post will be doing this for sure
  15. Aug 5, 2019 at 8:36 PM
    #435
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    Hey @crashnburn80 , you been happy with the TRD pad and Stoptech Cyro set up?
    I picked up a set of TRD pads during the TRD 40% off sale and just found a $100 off $200 purchase, bringing the Stoptech Slotted Cryos to $200 shipped.
    After running these for a while, do you think the cyro treatment is worth the extra $35 a rotor?
    Appreciate the thorough write up!
  16. Aug 5, 2019 at 10:12 PM
    #436
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    I would also like to know how the pads and rotors are holding up. I'm at 78,000 on my brakes and my rotors are starting to shimmy on long drives. Are the stop techs worth the extra money or are oem rotors and TRD pads sufficient for the cost?
    Pella likes this.
  17. Aug 6, 2019 at 3:54 AM
    #437
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Hey @YotaBum , I just did the TRD pads and cryo rotors last month, have about 1100 miles on them.
    It’s a great upgrade over stock IMHO. Brakes grab nicely and don’t fade. Shorter stopping distance. Feels more sure and stable but then again, I found a stuck piston in my drivers side caliper....
    Norton likes this.
  18. Aug 6, 2019 at 10:52 AM
    #438
    wangamachang
    wangamachang Well-Known Member
    San Jose
    '09 Timberland Mica Tacoma TRD Off-Road 4x4 Access Cab
    thanks for the writeup. need to upgrade the pads and rotors now with the added weight on my truck!
  19. Aug 6, 2019 at 10:56 AM
    #439
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I am waiting on my Wilwoods kit to be shipped to me and can report back. Wilwood has been around forever and used in hot rods and such for years. I do not see why it wont. They also offer a version with external dust shields for extra dirt protection.
    Just ordered some DBA 4000 T3 rotors to go with them. Wheelwell.com has $200 off $400 right now. Great pairing. The rotors in the SOS kit are not anything special, just stoptech in a certain size or fancier Centric rotors unless you buy the higher end setup with 2 piece rotors. I thought about that but if I have an issue off road its harder to replace. RR-Racing has a setup that uses the wilwood aero6 but you can mate with 5th Gen T4R rotors. Easy to replace if needed. All in all it cost me around $1400 I believe
  20. Aug 6, 2019 at 12:59 PM
    #440
    medjah
    medjah Volleyballing
    Blake
    Austin, TX
    09 Barcelona Red DCSB SR5 TRD OR
    OME 887 Springs OME 90000 Shocks OME Dakar Light Duty Leafs Wheelers SuperBump Bumpstops w/ u-bolt flip Sway Bar relocate Red Brake Lines Ultimate Headlight Upgrade Airflow Snorkel Rear diff breather mod CMC AtTheHelm Bed Stiffeners AtTheHelm Front Rail Chock System Hood Struts
    @crashnburn80 Still happy with this setup? I need to replace my rotors and pads. Was thinking of doing the same. Just want to double check. Thanks!
