Brake upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmb1985, Sep 20, 2009.
  1. Sep 20, 2009 at 6:02 PM
    jmb1985
    jmb1985 [OP] Active Member
    Middletown NY
    06 DCSB
    Looking to replace my brakes on my 06 4x4 sport. Any suggestions. Would like to do some cross drilled with ceramics but havent seen any reviews
  2. Sep 20, 2009 at 6:06 PM
    Brunes
    Brunes abides.
    Rotorhead
    Cross drilled leaves room for stuff to get stuck in your discs...they are also prone to cracking (I've heard) under high heat/cooling cycles.
    Slotted will help...Upgrading your pads with a good pad...like EBC and some good brake fluid is the way to start. Little bits, until you get the result you want.
  3. Sep 20, 2009 at 6:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im gonna say go with some slotted rotors, and some hawk ceramics. i have slotted s/p rotors, and hawk lts pads, and they work great. go here......
    http://raceshopper.com/
    some of the best prices and customer service i have ever seen.
  4. Sep 20, 2009 at 7:27 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    This would be a good time to switch to stainless steel brake lines too...
  5. Sep 20, 2009 at 7:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x2
  6. Sep 20, 2009 at 7:40 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    yep, stainless lines, slotted rotors and ceramic pads are what im running. I sometimes slam on the brakes on offramps just to 'test' them lol
    works bitchin'
  7. Sep 20, 2009 at 8:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Where did you get your brake lines from? And, has anybody tried using the TRD BBK for FJ's on the Tacoma?
  8. Sep 20, 2009 at 11:02 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    got all the front brake parts from http://www.wheelersoffroad.com/05uptacomabrakes.htm
    took a month to get the parts (they were out of stock on everything when I ordered) It wasn't urgent so I waited. others have gone to
    http://raceshopper.com/index.shtml
    I think the BBK wont fit with 16" rims and it's like $2000+
    not worth it IMO
    good luck
  9. Sep 20, 2009 at 11:13 PM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
