Brake Upgrade?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vanderjdm, May 18, 2018.
  1. Jun 13, 2018 at 7:52 PM
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    you can also order brembo blank rotors and pads from autozone.... id highly consider this route, and if I had known I would have gone this route. Oem stuff is just too damned expensive. There is evidently a TRD pad, but someone on here mentioned i had to go through some dealer in SC?
  2. Jun 13, 2018 at 7:58 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I wonder if the 4 runner swap works on 3rd gens
    Know it's a thing for 2nd Gen. And it's a significant upgrade to piston size.
    When I need brakes I'll consider it. I don't really find mine to not work or be spongey but truck is getting heavy with all the armour etc . Should upgrade
  3. Jun 13, 2018 at 7:59 PM
    SnowFarmer
    SnowFarmer I intend to live forever, or die trying.
    Corona, CA
    '17 TRD Pro
    I can afford Gas.
    Second stupid question and thanks for your help. What's a blank rotor and what is the benefit of them?
  4. Jun 13, 2018 at 7:59 PM
    Joe23
    Did you try the 4runner swap?
  5. Jun 13, 2018 at 8:02 PM
    SnowFarmer
    Corona, CA
    '17 TRD Pro
    I can afford Gas.
    What is this? Looking for 4Runner pads opposed to Tacoma?
    I would like to swap out the rear end of a 4Runner for the rear disc. Right now I just need new fronts.
  6. Jun 13, 2018 at 8:09 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Changing pads, calipers, disks will not change a “spongy” feeling. Lines, master cylinder and correctly bleeding will change that. So assuming you are using the correct term, what most are suggesting will not help.
    From what you describe, I’d change lines to braided and make sure you bleed correct before spending more $$$$.
    hiPSI, johntoyota and Joe23 like this.
  7. Jun 13, 2018 at 8:17 PM
    Joe23
    Complete swap out calipers, rotors pads.
    From what I understand it's a significantly bigger piston so you get more stopping power
  8. Jun 13, 2018 at 8:21 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    It took time to adapt to them. I locked them up a few times on accident when I first got the truck. The problem is the pump doesn't pressurize the system until a demand is made. So if you apply 1/2" of pedal you initially just get whatever mechanical pressure that creates initially then when the pump kicks on it ramps way up. Now I always start with minimal depression to get the pump to come on then I start modulating.
    Joe23 likes this.
  9. Jun 13, 2018 at 8:26 PM
    Joe23
    Driving it home when I picked it up I locked up haha wasn't used to it.
  10. Jun 13, 2018 at 9:20 PM
    phsycle
    phsycle Well-Known Member
    CA
    I’m still getting used to it. I still find myself trying to find that braking point and suddenly throwing everyone forward in their seats.
  11. Jun 13, 2018 at 9:40 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    SnowFarmer and Clearwater Bill like this.
  12. Jun 13, 2018 at 11:38 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    True stopping power is simply a function of coefficient of adhesion of your tire on the road surface. That's it. Bigger piston, slotted rotor, disc versus drum, etc has no bearing on actual stopping distance. What those things will help is brake fade if applicable.
    Simply put, if your current brakes have the ability to activate ABS, then from there it's all about tires and road surface.
  13. Jun 14, 2018 at 5:49 AM
    Vanderjdm
    Vanderjdm [OP] Well-Known Member
    2018 Off Road
    5% Tint, ARE V-Series w/ Yack Rack, Ebay Grill, Emblem Black Out Kit, Bumpershellz, Predator Tube Steps, Radioknobs by Tacowiede, Kicker Speaker Upgrade
    Maybe spongy isn't the best term. I went from a sports sedan to this truck. I miss the firm bite those brakes had versus this. Maybe what I'm saying is that the brakes don't slow/stop the truck as quickly/effortlessly as I wish they did.
    Obviously a lot of that has to do with weight. This thing's certainly a lot heavier than my car was. Maybe I just need more pistons and bigger pads up front to really like the brakes. This is also the first car I've had in years with rear drums so that may be part of it too. I've also not had a truck in 20 years.
    All that being said I am getting used to them now, just need to input a lot more brake pedal for a longer period of time to stop than I prefer.
  14. Jun 14, 2018 at 5:55 AM
    Joe23
    Rear brakes don't do enough.
    The problem is you're comparing a 4500lbs truck to a sports car that probably weighted 2500lbs.
    Adjust your driving to the vehicle you have.
    For what it's worth my truck has better brakes than my car but that's probably because my car is old and the master cylinder is getting old.
    Vanderjdm[QUOTED][OP] likes this.
  15. Jun 14, 2018 at 6:37 AM
    #35
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    Size of the piston in the brake caliper does not dictate stopping power. Single-stop power on any modern vehicle is dictated by the suspension design, weight distribution, tires, and road surface.
  16. Jun 14, 2018 at 6:39 AM
    #36
    STexaslovestacos
    Sam
    2017 MT TRD OR
    If you want the Tacoma to feel more like a sports sedan under the brakes you need to put sports-sedan type tires on it and probably lower it a good six to eight inches at minimum. Plus braided lines.
    hiPSI likes this.
  17. Jun 14, 2018 at 8:28 AM
    #37
    Joe23
    With bigger tires and weight it makes a difference.
    More surface area between pads and rotors being able to apply more force .
    I agree on terms of stock truck it's based on tires etc. But when you're referring to more rotational mass from heavier, bigger tires caliper size and power do have an impact on stopping power.
  18. Jun 14, 2018 at 9:07 AM
    #38
    STexaslovestacos
    Sam
    2017 MT TRD OR
    Find me a stock car for sale today that is incapable of locking its brakes up. They don't exist.
    Multi-piston designs are for heat capacity, pad size, more even pad wear, and packaging, not clamping force. Getting sufficient braking power to overwhelm the tires is simply not a problem in modern vehicles, and hasn't been since, oh, the late '70s.
  19. Jun 14, 2018 at 10:14 AM
    #39
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Physics disagrees with you Joe, as long as your brakes have the ability to initiate a locked rotor condition in a given time.
    Now, if you add so much weight that your brakes no longer have the ability to do this, then of course you need bigger parts. I personally haven't driven a vehicle in 40 years that couldn't lock the brakes as soon as you push hard on the pedal. After that... it's tires and road. The vehicle's mass and velocity will of course dictate the length of the skid but bigger calipers don't do anything for you there.
    Joe23[QUOTED] likes this.
  20. Jun 14, 2018 at 1:27 PM
    #40
    Joe23
    Did you miss the part where I said stock ok but outside of stock?
    Referring to the guys running 35s and lots of weight
