brake upgrades
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoyaki, Mar 19, 2010.
  1. Mar 19, 2010 at 10:04 AM
    tacoyaki
    tacoyaki [OP] Active Member
    Hey there,
    I just purchased an 06 dc trd or...its my first truck so im just getting used to the weight of the truck. i noticed that the braking is not as good as my car (due to the weight i'm assuming)...what do you guys recommend for better stopping power?
    what's everyone running around here
    thanks in advance
  2. Mar 19, 2010 at 10:16 AM
    81shark
    81shark Well-Known Member
    driving a truck like a truck helps.
    i don't have any problem stopping
  3. Mar 19, 2010 at 10:22 AM
    HOSS454
    HOSS454 Well-Known Member
    Pukalani
    08 Sport
    Bolt ons here and there
    if you want a rear disc setup, check out tundraracing.com.
  4. Mar 19, 2010 at 10:25 AM
    tacoyaki
    no stopping problems here, like most people on this forum...i'm just looking for upgrade options.
    with that said...what kind of slotted rotors are some of you running?
    TIA
  5. Mar 19, 2010 at 10:25 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    ^ DO NOT DO THIS.
    Call Edwin at RaceShopper.com and order some SP Performance slotted rotors and Hawk pads. Install them, bleed your brakes, adjust your rear drums, and you'll be fine.
    If you want a little more performance then swap out your flexible rubber brake lines for some stainless braided lines.
  6. Mar 19, 2010 at 10:26 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    I reccomend the braided brake lines. helps a ton.
  7. Mar 19, 2010 at 10:38 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    if you search around, guys will say hawk LTS pads and slotted (NOT drilled) rotors from raceshopper.com, SS lines and a brake fluid flush. thats about all you can do. rear discs are a waste.
    im recently installed some 285s and SS lines, and will be installing some hawk pads on OEM rotors this weekend, i'll report back if you wish.
  8. Mar 19, 2010 at 10:42 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    +1. One of my future mods.
  9. Mar 19, 2010 at 10:43 AM
    bradu81
    bradu81 Well-Known Member
    N. California
    Silver Dbl Cab 4x4
    I'm using DBA slotted rotors on my WRX...great upgrade over stock rotors for the subaru. Don't know about the truck...but its a good product overall.
  10. Mar 19, 2010 at 10:46 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    check out crownperformance.com for custom SS lines. got a set of 4 ext by 5" for my lift for $130 shipped to my door.
  11. Mar 19, 2010 at 10:47 AM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    drive slower.
  12. Mar 19, 2010 at 10:52 AM
    Tacomagator
    Tacomagator Well-Known Member
    I had my fluid flushed and put on SS brake lines. You can tell a big difference with the ss lines.
  13. Mar 19, 2010 at 1:55 PM
    mycoma
    mycoma Active Member
    Which ss break lines? I have an 08 4x4 DC, Where did you get them?
  14. Mar 19, 2010 at 3:10 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    crownperformance.com as i mentioned earlier in the thread. got four new lines all 5" longer for my lift to my door for $130!
  15. Mar 19, 2010 at 3:49 PM
    dylandercole
    Dylan
    Or check out wheelersoffroad.com thats where I got mine.
  16. Mar 21, 2010 at 1:06 PM
    Tacomagator
    yep these
  17. Sep 5, 2011 at 12:24 AM
    Muscles
    Muscles Well-Known Member
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    I use the gas as a break.....get a 10 second eye lead time and if you see you need to stop soon well lay off the gas... :/ never have had problems with the brakes and get great mpg :p
  18. Sep 5, 2011 at 11:23 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Just wondering how braided brake lines could improve performance.
  19. Sep 5, 2011 at 12:10 PM
    Rellik01
    Craig
    Windermere, Florida
    Thanks for the quick reply
  20. Sep 8, 2011 at 10:22 AM
    Hockeyfan
    Hockeyfan Active Member
    Nigel
    Edmonton, AB
    08 BSP Double cab TRD
    Borla cat back exhaust
    hmmm.... sounds good. my mechanic said any ceramic brake pad would be an improvement. I'm expecting my 5100's at my door any moment now, so we'll get them on first and see if that impacts braking performance at all... if not then i'll be ordering up some Hawk LTS / SS brake lines.
    thread hack : i'm Super pumped about the 5100's. =)
