Brake Vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Greatdane01, Jan 18, 2023.
  1. Jan 18, 2023 at 2:07 PM
    Greatdane01
    Greatdane01 [OP] Well-Known Member
    3rd Gen TRD Sport Tacoma
    3” lift, XD Wheels, BFG Tires, GT momentum cold air intake
    2020 with 75k miles. I'm starting to notice a vibe or shimmy when breaking, especially at highway speeds. I'm seeing posts from others saying they get over 100k on brakes. I realize everyone's vehicle / driving is different but just trying to get some input on when I might be ready for brakes. Which leads to- how can I check them? Is replacing them difficult or something I can do in my garage? I've replaced struts, leaf springs, arms, etc before. Just don't have any brake experience.
  2. Jan 18, 2023 at 2:09 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you can check them with a run out gauge...if the steering wheel shakes when applying the brakes there warped...aftermarket pads can vibrate also
    Greatdane01[OP] likes this.
  3. Jan 18, 2023 at 2:13 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    Sounds like your rotors are warped.
    Greatdane01[OP] and airmax233 like this.
  4. Jan 18, 2023 at 2:21 PM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    My factory brakes shimmied a bit. I had them changed pads/rotors at 50k and they were getting low but not quite done yet. The brand new brakes have the same little shimmy. The truck has always done it. I’ve read others with the same complaint, I guess I’ve learned to live with it since the truck will stop on a dime and pick it up.
  5. Jan 18, 2023 at 2:24 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Check that the lug nuts are torqued to spec. If lugs are torqued properly then check for warped disks.
  6. Jan 18, 2023 at 2:27 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Super easy to change. Vibs are due to pad building up on rotors.very rare rotors warp.
  7. Jan 18, 2023 at 2:31 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
  8. Jan 18, 2023 at 2:39 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
  9. Jan 18, 2023 at 2:54 PM
    Greatdane01
    Yes I feel it in the brake pedal, as I said usually on the interstate like when I have to brake at 65mph for slowing traffic etc. Not so much at a traffic light going 35mph.
    JJ Diablo[QUOTED] likes this.
