Brake warning light on after ball joint replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The_Outpost, Feb 11, 2024.
  1. Feb 11, 2024 at 12:28 PM
    The_Outpost
    The_Outpost [OP] Member
    5100s, AAL
    Here’s the deal. Replaced passenger side upper ball joint to pass inspection and when I fired it up to test drive, brake warning light came on.
    After some research, I checked the brake fluid level and it was at the high mark. No leaks in the brake system. Parking brake engages but doesn’t stop the truck. Drums were replaced last spring.
    Where do I go from here?
  2. Feb 11, 2024 at 12:31 PM
    Bishop84
    Bishop84 Well-Known Member
  3. Feb 12, 2024 at 9:15 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Concur you probably stressed the ABS Sensor cable to that wheel you did the ball joint on.
  4. Feb 12, 2024 at 3:12 PM
    The_Outpost
    5100s, AAL
    Just picked up the recommended Bluetooth scanner and ran the complete scan and no error codes came up. What could I be missing?
  5. Feb 13, 2024 at 10:07 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Did you look under the truck at the wiring to the ABS Sensor?
  6. Feb 13, 2024 at 10:21 AM
    ddaykpa
    ddaykpa Well-Known Member
    brent
    SE Houston, TX
    2015 MGM tacoma 4x4 DCLB trd
    n fab steps. redline hood struts, MATTGECKO bed lights, truxedo lo pro tonneau fab fours front and back bumpers old man emu 887 coils dakar rear springs ome rear sport shocks tint, removed rear seats, anytime driving light mod, anytime power inverter on. 2 ac plugs in cab, 4 constant power usb ports husyliner mats, airraid intake, fat matted floor and rear cab wall. hood deflector window deflectors, all in one flip key, painted interior plastics. trd pro wheels. rear molle panel.homemade trailer plug bracket. added Signal Stat 77-570 for rear cab area lighting. tacodane hoodlight kit Total chaos UCA. Ac Max mod
    he said the Brake warning light was on.. separate from ABS. hence no codes.
    also states that parking brake engages but does not stop the truck
    possible the parking brake not releasing fully and triggers the light.
    id check for drag on back brakes next and go from there
    just responding and guessing given info provided in first post.
    Steves104x4 likes this.
  7. Feb 13, 2024 at 11:13 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Most common issues for the Brake Light are low fluid level and Parking Brake Switch.
    I misunderstood that the ABS Light was also on...
  8. Mar 1, 2024 at 2:12 PM
    The_Outpost
    5100s, AAL
    Update - through closer inspection of the rear hubs, discovered the pass side parking brake cable was broken where it passes into hub. Replaced the cable and both abs harnesses and still have dash brake light illuminated. The parking brake switch is a pain to get at but going to get after it tomorrow and see if that is the culprit.
  9. Mar 2, 2024 at 10:21 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Try pulling off sensor connector on master cylinder and see if light turns off. Mine was coming on and ended up being the switch on the master.
  10. Mar 2, 2024 at 10:36 AM
    The_Outpost
    5100s, AAL
    Just fixed the issue. Turns out the parking brake switch had a small bit of corrosion. Cleaned it off and the lights went off. Not sure why the abs light went off too, maybe because of the new harnesses. Anyway, good to go!
    hemitruk and Jimmyh like this.
