Brake warning light on and off.
Discussion in '1st Gen. Tacomas (1995-2004)' started by kinside, Jan 3, 2009.
  1. Jan 3, 2009 at 1:54 PM
    kinside
    kinside [OP] Member
    recently my brake light warning on the cluster turns on and off for no reason even when my e brake is not engaged.
    I'm planning to replace my brakes soon. could that be the problem.
    anyone here can recommend me a good site to order my brake system from online?
  2. Jan 3, 2009 at 1:55 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    are you low on brake fluid?
  3. Jan 3, 2009 at 2:36 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
  4. Jan 3, 2009 at 3:44 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    OK, I have to ask, WTF is a "brake system"?
  5. Jan 3, 2009 at 4:07 PM
    TicTacOma
    Columbia,SC
    Well, I would have to say it's "his" way of saying..... Brake System. Sounded pretty understandable to me.
    Did ya notice it was his first post? New guy needing help from the regulars. Hope he didn't get scared away. I learned my lesson about chirping without a warm hello.
  6. Jan 3, 2009 at 8:09 PM
    kinside
    kinside [OP] Member
    brake fluid is full.
    what i meant is parts like drums, disks, pads, shoes. where do you all buy your parts from?
    yes i'm new to this forum. so HELLO :wave:everybody. Very cool forum and i see its pretty active too. looking forward to learning more about my truck and communicating with you.
  7. Jan 4, 2009 at 1:40 AM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    I just get my stuff at kragen, tried dealership pads for awhile, they worked the same as aftermarket so i just went cheap
  8. Jan 4, 2009 at 5:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Check your ebrake handle (pull). Sometimes the ebrake cable can get too much slack in it and cause the light to come on. When you pull the ebrake handle - you're supposed to get 12-18 clicks. If you get a lot more than that, the cable needs adjusted.
    However - since you're changing the rear brake shoes anyway, don't adjust the ebrake cable until AFTER you put new shoes on.
    You might not need to adjust the cable after you put new shoes on.
    http://www.lieblweb.com/tacoma/Mechanical/EbrakeAdjustment/ebrakeadjustment.htm
  9. Jan 8, 2009 at 5:09 PM
    swsteven
    swsteven Well-Known Member
    houston tx
    2001 tacoma trd
    3 inch lift bilsteins and aal 16 inch pro comp wheels, m/t tires
    well im a honda mechanic and usually they have a brake switch under the brake pedal bar , not to sure about the tacoma i havent looked under my pedal
