Brake Warning Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by window, Jul 11, 2022.
  1. Jul 11, 2022 at 5:20 AM
    window
    window [OP] Active Member
    NW Wisconsin
    07 Tacoma, 4Cyl,4WD
    I put a new caliper on driver side. I disconnected the speed sensor because the ABS and Traction control lights have been on for awhile and I figure I'll get a new sensor and the connector was not easy to disconnect. Is the light on because there's something in the electrics logic that it sees it not connected? It wasn't on before I did the brake work and I don't think I did anything wrong in the caliper repair.
    The Owner's Manual has a comment on the light and warning tone. There's no tone, just a steady light. I checked all the fuses related to ABS prior to this job.
    I saw nothing similarly related in the search function for Brake Warning Light.
  2. Jul 11, 2022 at 5:21 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Check your brake fluid. If it's low, it will make the light come on.
    Jimmyh and SR-71A like this.
  3. Jul 11, 2022 at 5:34 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Brake fluid as mentioned above.
    Also I wouldn't leave the speed sensor line unplugged - good way for water and crap to get into the connector and give you issues down the road
    Jimmyh and six5crèéd like this.
  4. Jul 11, 2022 at 6:15 AM
    window
    NW Wisconsin
    07 Tacoma, 4Cyl,4WD
    The brake fluid reservoir is full. The connector is duct taped and zip tied to the A arm.
    What if I run a jumper wire between the blue and white receiver ends of the connector?
    If it's electric logic, wouldn't that 'solve' it?
  5. Jul 11, 2022 at 6:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    The light also comes on if the ebrake is engaged.
    While the brake may be released, the switch can stick and make it think the ebrake is still on.
    Jimmyh likes this.
  6. Jul 11, 2022 at 6:21 AM
    window
    NW Wisconsin
    07 Tacoma, 4Cyl,4WD
    I will check that but the Ebrake has been disconnected and all hardware (except handle) removed when
    I got a new frame 4 years ago. Rust is a bugger.
    I will add that everything works just fine but no one wants to have a light on. What happens when it really means it?
