Brake work recommendations - to flush or not?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cak, Sep 23, 2022.
  1. Sep 23, 2022 at 1:35 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I changed the brake fluid for the first time last year on my 20 year old Mustang. It had a slightly brown tint to it. Made it easy to see when I was at new fluid.
    Didn't feel a difference in the brakes and the car has never had a caliper or brake line go bad... IMO every 2 years is overkill. But I also change my oil every 10K. :anonymous:
  2. Sep 23, 2022 at 1:40 PM
    cak
    cak [OP] Well-Known Member
    Palo Alto, CA
    2017 V6 4x4 SR5 ACLB
    $189.95.
    They also tried to get me $73.44 to replace the cabin air filter, $54 to replace the wiper blades, and $87 to clean the battery and put in new pads.
    The pre-purchase package for regular services is a good deal, and apparently they make it up with the add-ons. Maybe I'll find someone else to do my brakes.
    davidstacoma likes this.
  3. Sep 23, 2022 at 1:47 PM
    jego
    jego Well-Known Member
    2020 TRD Off Road DCSB
    Wow. $54 to replace the wiper blades... o_O
    cak[OP] and davidstacoma like this.
  4. Sep 23, 2022 at 1:51 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Inspection of brake fluid fluid should include checking the water content. It should be changed at greater than 3% water content.
    I'm more cautious on my OR with the electro hydraulic system compared to vacuum systems. It more sensitive to water and the cost of issues is far higher.
    Barsoom and davidstacoma like this.
  5. Sep 23, 2022 at 1:56 PM
    Silver Jacket
    Silver Jacket Well-Known Member
    Howie
    2022 Silver TRD OR 4x4 MT
    Cabin Air Filter: costs $12, takes 5 minutes to replace without any tools required: Amazon.com: FRAM Fresh Breeze Cabin Air Filter with Arm & Hammer Baking Soda, CF10374 for Dodge/Toyota Vehicles : Automotive
    Wiper blades: costs $23 and takes 5 minutes to replace without any tools required: Amazon.com: MOTIUM 22"+20" Super Silicone Windshield Wiper Blades, Fit for J hook Wiper Arms (set of 2) : Automotive
    Battery pads: costs $6 for a set of 12 (so you can repeat this process 5 more times). Tools required: baking soda, toothbrush, rags. Takes 5 minutes to clean/replace: Amazon.com: 12 Pieces Battery Terminal Anti Corrosion Washers Fiber Battery Terminal Protector(Green, Red) : Automotive
    That last one, charging $87 to replace a $1 part and about 5 minutes worth of scrubbing the battery terminals is especially egregious.
    Brake fluid flush and replace is NOT part of maintenance schedule.
    I personally wouldn't take my business to a dealership that tries to rip me off. I find it offensive and insulting, and would not reward them with a return trip.
    grogorat and cak[QUOTED][OP] like this.
  6. Sep 23, 2022 at 2:03 PM
    cak
    Palo Alto, CA
    Given that they charged me $30 for the inserts, that seems cheap :)
  7. Sep 23, 2022 at 2:06 PM
    jego
    OEM PART:
    Windshield Wiper Blade Refill
    Part Number:
    85214-0E140 $9.89, you would need two, $20
    Cabin Air Filter - Toyota (88508-01010) $37.20
    Quick search of the cost of parts at my local dealership.
    cak[OP] likes this.
  8. Sep 23, 2022 at 2:06 PM
    cak
    Palo Alto, CA
    Yeah I bought the inserts at the dealer and had ordered the other items before they returned the truck to me. I have one more pre-paid service with them, but it's probably time to find an independent shop.
  9. Sep 23, 2022 at 3:23 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    So I had my 2nd gen for 12 years and never changed the brake fluid, and it was still clear. I never even opened the cap. I figured it was a sealed system so why expose it to the air unless it was leaking.
  10. Sep 23, 2022 at 3:33 PM
    slistings
    slistings Well-Known Member
    SoCal
    Yeah, I'd say usage matters. For your everyday Tacoma, probably not necessary as you're likely never going to get to the point of boiling your brake fluid. If you regularly tow a large trailer, maybe at the two year mark? Porsche recommends 2 years across many (maybe all) of their vehicles. My track bikes get flushed every 6 months.
    Barsoom likes this.
  11. Sep 23, 2022 at 3:41 PM
    Bishop84
    Bishop84 Well-Known Member
    I GOT THIS
    ITS HYGROSCOPIC DUMMY.
    I had someone correct me about this 15 years ago in front of an entire seminar. It was awful.
    nDub and davidstacoma like this.
  12. Sep 23, 2022 at 3:45 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Correct. My theory is many years ago some absent minded professor spelled hydro wrong and the masses went with it from that day forward because a “perfesser” can’t be wrong.
    Bishop84[QUOTED] likes this.
  13. Sep 23, 2022 at 3:45 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I blame speech to text. :anonymous:
  14. Sep 23, 2022 at 3:48 PM
    davidstacoma
    David
    NC
    I was just looking at some of those brake fluid test meters. Never used one but not so expensive so may buy one and use it. In a few more years. :D
  15. Sep 23, 2022 at 4:14 PM
    #35
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    You can get test strips as well.
    davidstacoma[QUOTED] likes this.
  16. Sep 23, 2022 at 4:19 PM
    #36
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    It's almost as if a $8 bottle of fluid every 2-3 years is equally cost effective, very interesting.
  17. Sep 23, 2022 at 4:27 PM
    #37
    davidstacoma
    David
    NC
    Yeah but then there’s the labor for flushing …
  18. Sep 23, 2022 at 4:33 PM
    #38
    davidstacoma
    David
    NC
    I was looking at those as well. seems almost all the strips are for measuring corrosion, only saw one brand of strips for moisture in a brief search. Did see this article where moisture strips could absorb moisture from the air so could be quesrionable trying to measure 2% moisture in brake fluid.
    https://www.brakebleeder.com/solutions/brake-fluid-testing/resources/copper-vs-water/
    I’m just learning about this stuff I only play a brake fluid tester investigator on TW, in real life I’ve always went by color. Which I do concede might be helpful regarding corrosion but couldn’t tell squat about moisture.
    I watched a few youtube videos on moisture meters, one said to test the meter is working by measuring new brake fluid and showed one bottle was 1% or less. another measured 4 new bottles and all were 2% .. with a flush recommendation of 3% that’s either wrong reading or the fluid is poor quality. I would say the meters suspect in that case.
  19. Sep 23, 2022 at 4:47 PM
    #39
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Last time I checked gravity didn't charge labor.
    Barsoom likes this.
  20. Sep 23, 2022 at 4:58 PM
    #40
    davidstacoma
    David
    NC
    lol you do realize while humorous that makes no sense right?
