Braked
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joe 1881, Jul 24, 2024.
  1. Jul 24, 2024 at 4:38 PM
    Joe 1881
    Joe 1881 [OP] Member
    Nithshade
    My 2023 Toyota Tacoma I have to replace new brakes at 10,000 km and rotors there’s so hot you can even touch them so should I upgrade to heavy duty brakes?
  2. Jul 24, 2024 at 4:39 PM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    Warranty? Go to the dealer
  3. Jul 24, 2024 at 4:42 PM
    Joe 1881
    Nithshade
    Hi, I did it and they told me they’re gonna cover it this time but the brakes are still really hot even after the new ones they put on I was wondering if something is wrong with the callipers
  4. Jul 24, 2024 at 4:50 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Refrain from drunk texting and revisit this in the morning.
    BlackTRD4Me, JDAM, 02Duck and 7 others like this.
  5. Jul 24, 2024 at 4:53 PM
    Joe 1881
    Nithshade
    What are you talking about?
  6. Jul 24, 2024 at 4:53 PM
    C-Rok275
    2017 TRD Pro
    Maybe a caliper problem, but they should have found that.
    Any chance you’re riding the brakes?
  7. Jul 24, 2024 at 4:54 PM
    Joe 1881
    Nithshade
    No I was thinking about upgrading my disc brakes to heavy duty
  8. Jul 24, 2024 at 5:02 PM
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    keep in mind brakes are supposed to get hot and if one side is hotter than the other, this is normal too.
    The normal operating temps for disc brakes are well into the 'BBQ bare skin' range
    if you suspect the caliper is seizing up, jack up and spin while hot.
    check for bearing play while you are at it,
    if there is growling noise while driving along with excessive heat, time for new bearings
    BlackTRD4Me, 02Duck and Chew like this.
  9. Jul 24, 2024 at 5:04 PM
    Joe 1881
    Nithshade
    Thank you it’s a 2023 Tacoma nightshade edition limited 10,000 km
  10. Jul 24, 2024 at 5:45 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    An easy way to check for dragging brakes is to cruise for several miles and (safely) pull over and coast to a stop without touching the brake pedal. You can gently use the hand brake at a very low speed.
    Get out and reach through the wheel spokes and feel the rotors - they should be cool and about equal temperatures.
    If they are hot they are dragging for whatever reason, further investigation will be required.
  11. Jul 24, 2024 at 6:33 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Absolutely no need. I overloaded my truck dozens of times, zero issues with stock brakes and my truck is modified.
    If you need new brakes at 10K KM, something is definitely wrong.
    BMH, BillF1564, OZ TRD and 6 others like this.
  12. Jul 24, 2024 at 6:44 PM
    Joe 1881
    Nithshade
    I see thank you very much for your help I will take my Taco to my private mechanic that I was going to him for years so he can check the front end and the brakes
    Junkhead likes this.
  13. Jul 24, 2024 at 7:57 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Do you drive two-footed?
    Chew and Vlady like this.
  14. Jul 24, 2024 at 8:10 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    When do the brakes get “hot”?!
    These brakes last 40-120k miles for the fronts and 100k+ for the rears.
    Add some details to your post. And post up what the dealer said… I.e take a pic of their inspection paperwork
    BlackTRD4Me, Chew and Junkhead like this.
  15. Jul 24, 2024 at 8:19 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    i need a calendar......is today Friday?
    BlackTRD4Me, BillF1564 and shakerhood like this.
  16. Jul 24, 2024 at 8:24 PM
    RIX TUX
    2 possible reasons:
    1. you are too old and use left foot for braking
    2. you are too young and have a leadfoot on the gas pedal
    BillF1564 likes this.
  17. Jul 24, 2024 at 8:28 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  18. Jul 24, 2024 at 8:47 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Have you checked your rear brakes? I’m wondering if it dives when you stop because somethings going on back there that is making you mainly use the front? Does the ebrake work?
  19. Jul 24, 2024 at 9:20 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    ??? I'm at 188'000kms on my factory brakes all around. Still have 7mm on the front as of a month ago and i've towed many times including cars from Vancouver to Northern Alberta along with many other trailers and payload across the province and country.
    Explain your issue a little more.. was the hot brakes your reason for going in or were they also worn out? Where do you live/drive? Are you bombing through wet tailings areas?
  20. Jul 24, 2024 at 9:47 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    On 50 mph roads...
    joba27n and Chew like this.
