Brakes apply when cornering hard to the right...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jRock1, Aug 22, 2016.
  1. Aug 22, 2016 at 12:13 PM
    jRock1
    jRock1 [OP] Member
    My 2014 TRD is having an issue when I am driving fairly fast (40-55mph) and take a hard corner to the right. The driver's side front brake applies and the vehicle stability control indicator flashes. It basically pushes me into oncoming traffic. This has only happened a few times but it FREAKS me out and has almost caused me to get into an accident. Any idea on what this could be. I can't imagine i'm driving to fast around a corner. Seems like something else.
    Thanks!
    ChadsPride likes this.
  2. Aug 22, 2016 at 12:53 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Unless you're on a race track, I'd say taking a hard right at 50mph is pretty fast, especially in a pickup. Sounds like your truck got it right.
    In any case, check for any loose nut between the steering wheel and the front seat.
    ecoterragaia, Jimmyh, mwc273 and 2 others like this.
  3. Aug 22, 2016 at 1:34 PM
    jRock1
    jRock1 [OP] Member
    Thanks locster. I guess I don't feel like any of the times it happened were excessive for the conditions as I was keeping up with traffic. I'm not sure why there would be a loose nut between the steering wheel and front seat? did you mean front wheel?
    thanks
  4. Aug 22, 2016 at 1:42 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Your truck has oversized tires on it? The stability control system is calibrated for stock tires, and is not aware the tire difference, so it is attempting to correct something that doesn't need to be corrected when cornering. You need to recalibrate it. Others will chime in on how to do so.
  5. Aug 22, 2016 at 1:44 PM
    jRock1
    jRock1 [OP] Member
    Thanks! Super helpful.
  6. Aug 22, 2016 at 1:55 PM
    Toyoda Tacoma
    Toyoda Tacoma Do or Do not there is no try.
    2019 TRD Double cab, Long box
    Roof Rack, Step Bars, 3” Rough Country lift 265/70/17 Goodyear DuraTracs
    LMAO
  7. Aug 22, 2016 at 2:01 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    I've heard of this happening, seems to be really dangerous.
    jRock1[OP] likes this.
  8. Aug 22, 2016 at 2:01 PM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I was just messing with you about the loose nut. Just that you said taking a corner at 50mph, I pictured a sharp 90 degree turn at that speed. That is insane for any vehicle on the road.
    Maybe you were referring to a wider sweeping turn on a highway. Then as others have mentioned, you can get the truck's sensors recalibrated by the dealer. It's still a hit and miss fix though, as many still have the same issues after recalibration.
    People usually get this problem after going with larger tires.
  9. Aug 22, 2016 at 2:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Turn off the system using the VSC button. I personally would not feel safe taking a Corner at 45 - 50 MPH.
  10. Aug 22, 2016 at 2:28 PM
    jRock1
    jRock1 [OP] Member
    Lol...yeah, sweeping turns but still fairly sharp coming down from the mountains on the highway. Good to know i'm not the only one.
