Brakes are stiff while driving.
Discussion in 'Technical Chat' started by haolerot, Jul 2, 2012.
  1. Jul 2, 2012 at 6:29 PM
    haolerot
    haolerot [OP] Well-Known Member
    03 Tacoma TRD
    Today while driving home, my brakes suddenly felt very stiff, not fully locked but still very hard to press.
    After getting home I visually checked all the lines, but everything looked good. Then while the truck was running, I slammed down on the brake pedal as hard as I could. I felt a popping noise (air?) in the pedal and it felt as if it was back to normal. So then I took the truck for a spin, and the problem was back within 2 minutes of driving.
    Any clues on what this could be? (sorry, not very mechanically inclined)
  2. Jul 2, 2012 at 6:33 PM
    haolerot
    03 Tacoma TRD
    I haven't changed or added anything to my truck for about 6 months.
  3. Jul 2, 2012 at 6:36 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Power brake booster. [​IMG]
  4. Jul 2, 2012 at 6:47 PM
    haolerot
    03 Tacoma TRD
  5. Jul 2, 2012 at 7:30 PM
    haolerot
    03 Tacoma TRD
    Any ideas?
  6. Jul 2, 2012 at 7:53 PM
    BamaToy1997
    Bill
    Navarre, FL
    Can you provide more info? Do you have ABS? Was it a gradual stiffness to the pedal?
  7. Jul 2, 2012 at 8:19 PM
    haolerot
    03 Tacoma TRD
    :cool:
    Yes, I have ABS.
    While the truck is off, I depress the brake pedal. After starting it up, the pedal slowly falls.
    While the truck is on, whenever I pump the brakes I have resistance and its slow(not as much when the truck is off)
    Also while randomly pumping the brakes, they sometimes feel 100% normal, but then go back to being shit on the next pump.
  8. Jul 2, 2012 at 10:19 PM
    haolerot
    03 Tacoma TRD
    anyone?
  9. Jul 3, 2012 at 12:15 AM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Sounds like the vacuum line to the BB isn't connected. Check the line from the booster to your intake plenum. Depending on your intake to the throttle body something may have made it through and clogged your line.
    Typically it will feel stiff as if the truck is off with no power.
  10. Jul 3, 2012 at 5:30 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Damn you; now I'm getting a gradual stiffness. It's just NOT in my brake pedal. [​IMG]
  11. Jul 3, 2012 at 5:48 AM
    BamaToy1997
    Bill
    Navarre, FL
    I believe you may have a faulty brake booster. It sounds more and more like it. My concern would be the POP you heard when you slammed on the brakes. It may be a slight internal rupture of the diaphram inside the booster. Not 100% sure of course, but doesn't sound good.
    I disagree. If he starts the truck with his pedal pressed, and gets a gradual fade, that means his booster is engaging (at least to some degree) If he had no vacuum to the booster, it would remain a hard pedal at all times.
    LMFAO
  12. Jul 3, 2012 at 12:21 PM
    haolerot
    03 Tacoma TRD
    I tried disconnecting the vacuum hose that connects to the BB, then started the truck up.
    It was a much different feeling, as I was getting no airflow at all. The feeling im getting is a slow pedal drop.
  13. Jul 3, 2012 at 1:50 PM
    BamaToy1997
    Bill
    Navarre, FL
    So even when you are holding the pedal, it continues to "fade" or drop down? Maybe I misunderstood what you were saying in your previous posts. If that is the case, look for a possible leak. If you cannot find a leak at all, then suspect a master cylinder.
    I apologize if my misunderstanding of your description lead you in the wrong direction.
  14. Jul 3, 2012 at 1:55 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    would it be smart to go ahead and replace the master cylinder, since its not hard or expensive, new brake fluid, and if its still doing it that would peg the BB
    they all wear out over time, so its not like throwing money away.
  15. Jul 3, 2012 at 7:51 PM
    haolerot
    03 Tacoma TRD
    Correct.
    Though now when I press on the brake pedal, I also hear almost 'wheezing' sound from under the hood. (possible bb?)
  16. Jul 3, 2012 at 8:28 PM
    BamaToy1997
    Bill
    Navarre, FL
    Wheezing sound like a vacuum leak?
  17. Jul 3, 2012 at 10:05 PM
    haolerot
    03 Tacoma TRD
    Possibly. I'm not sure where it would be leaking though.
  18. Jul 4, 2012 at 2:58 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Hmmm...
    You say you haven't noticed any leaks, but what about the overall level of brake fluid in the master cylinder? Is it full to reasonably full or very low?
    Check the rear drums and their condition/operation. Remove the drums, etc.
    Couple reasons...
    - On vehicles with drum brakes, much of the actual "pedal feel" comes from the rear brakes/drums.
    - A wheel cylinder can/will leak and will not be the most obvous spot from just looking. It can coat everything inside there, making a big mess. Also a suspect here in the "popping" noise you heard.
    - Rear drum issues will make a car brake incredibly oddly. And bad looking/sounding stuff to.
    - Check that all interal drum brake hardware (springs, hold down pins, etc) are not missing or broken causing a reactionary problem where the shoe could jack against the inside of the drum.
  19. Jul 4, 2012 at 7:04 PM
    noSKills858
    Alex
    Poway, CA
    Alright I misunderstood the issue also.
    Have you done anything to your truck recently, like adding new or longer brake lines? If so that will make the pedal feel softer with the expansion of the braided lines. If not it does sound like you have a leak somewhere. If you have to keep adding brake fluid then it's a big sign it's dripping out. I've rarely heard of brake boosters going bad on yota's.
  20. Jul 6, 2012 at 6:25 AM
    BamaToy1997
    Bill
    Navarre, FL
    Waiting on OP at this point to give us an update. Kinda curious what happened.
