Brakes 'clank' when I apply them
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1914, Jun 21, 2013.
  1. Jun 21, 2013 at 4:02 AM
    1914 [OP] Member
    I have a 2007 Taco 4x4 SR5 extended cab, non TRD model.
    When I apply the brakes it's making a sound I can hear underneath like something is binding, a linkage or something. To me, it sounds like a kink in the brake cable, or something is getting hung up somewhere, but I can't identify where by looking underneath and tugging at things.
    The noise is a one shot deal where it occurs only once as I step on the brake. It's not continuous or repeating like worn brake pad noise, which would be a completely different type of sound that I would definitely recognize. I replaced my calipers (greased the pins) and pads. Strange enough, the noise went away for a few weeks after that, but then returned again.
    Rears are fine, I have plenty of shoe left (again, different noise even if they were worn). The truck only has 60k on it and no off road use. I don't drive it hard at all.
    Anyone ever experience this or have any ideas what I can check? To make it more difficult to check, it only seems to make noise when the vehicle is rolling. So I can't have someone sit in the cab while parked and apply the brake while I'm underneath. And I don't really want to hold the frame while laying on my creeper as it's moving either!
  2. Jun 21, 2013 at 6:38 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    One shot deal...?? As in....the first time you step on the brakes every time and that's it until you get in the truck again the next time? Or does it happen every time you step on the brakes?
    Does it do it in reverse? Do you feel any difference in peddle pressure?
    Have you driven the truck in 4WD - do you get the same results?
    You replaced your calipers - what did you buy? OEM or aftermarket?
  3. Jun 21, 2013 at 6:44 AM
    TDubber
    TDubber Well-Known Member
    Dale
    El Cerrito, CA
    TRD OR
    Sweet ones.
    I experience the exact same thing. It happens the first time I touch the pedal. Forward/reverse doesn't matter. I have to press the gas get moving again, then the next time I touch the brake, I hear it. It doesn't matter how hard/soft I apply the brakes. It does it regardless. I've driven with it for a couple months, no serious issues. I'd be curious if someone has a fix tho.
  4. Jun 21, 2013 at 6:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    the pads have a little bit of "float" to them. The sound is normal.
  5. Jun 21, 2013 at 6:58 AM
    Major91
    Major91 Well-Known Member
    Masshole
    2009 TRD OffROAD Barcelona Red
    On Anytime Fog Lights Satoshi Grillcraft Misc LEDS 5100's all around Konig's16". Duratracks, debadged,tinted fronts, custom shifter, flyzeye
    This is true ^^^^^
  6. Jun 21, 2013 at 8:44 AM
    1914 [OP] Member
    Each time I step on them. No matter if it's in reverse or 4x. Brakes feel firm and normal. The calipers were remanufactured OEMs and the pads were after markets. But the problem existed before I did all that work.
    That's great... Pad slop.. I hope that's not it.
  7. Jun 21, 2013 at 8:49 AM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    my 2005 has done it since new, changed the pads and put the old plus the new anti rattle clips. put the new clips on the bottom like the factory and added the old to the top. this stopped the brake noise when first hitting the brakes going backward or forward the first time. should be able to buy just the clips by themselves. I think the noise is coming from having 4 piston calipers and only releasing from one end. just a thought. the pads have the holes already there and the extra tension keeps them from making noise.
  8. Jun 21, 2013 at 8:55 AM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    Same issue on mine, but only the first time I touch the brake going one direction. Doesn't happen again until I go to reverse. I agree with the floating pads. If you pull the tire, you can reach in and see that the pads move around by hand and can pretty well reproduce a similar sound.
    At one point, I thought it might be the upper or lower control arms but I tried everything I could stressing them by hand and they didn't move at all and the bushings are there to prevent metal to metal.
  9. Jun 21, 2013 at 9:34 AM
    IsmellBacon
    IsmellBacon Well-Known Member
    Denver, Colorado
    TRD offroad double cab
    None yet, need to finish the HEEP first
    Check the torque on the bolts that hold the calipers and the discs/drums. If they are loose it could allow minor motion causing the "clank". Secondly, check your bushings on the front and rear suspension. If they are worn/broken down they can allow movement and directional shifting when applying the brake allowing it to collide with it's carrier. This happened in my old 2001 Pathfinder (POS of a vehicle.)
    Bacon
  10. Jun 21, 2013 at 10:18 AM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
  11. Jun 21, 2013 at 10:26 AM
    jmg256
    Al Tonter
    TRD Offroad
    From the other thread...
