Brakes dont seem to work so good..HELP!
Discussion in '1st Gen. Tacomas (1995-2004)' started by sir1123, May 24, 2012.
  1. May 24, 2012 at 5:50 PM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    so recently i fixed my lspv and that squared away my brake leak....but even before that all happened my brakes just dont feel good. i do n ot have abs and dont know if that would make them feel diff. it feels like the truck just doesnt want to stop. at high speeds coming to a stop they feel fine but going around town they feel as if i dont have very good stopping power. the truck just want to keep moving forward it seems like i have a load on the back...i need help it is starting to scare me...i testes last night and i cant even skid my tires when i slamm it to the floor. help
  2. May 24, 2012 at 5:53 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Were the brakes properly bled? Also, pads and rotors in good shape? Sounds like you have air in the system or a leak. Does the pedal hold pressure if you're stopped and just pressing on the pedal?
  3. May 24, 2012 at 6:05 PM
    sir1123
    Charleston
    yes it holds pressure. i have done a vaccum test and a booster test and they check out....i need to bleed again and get new lines but i would think i could lock mine up without abs but maybe i not going fast enough. they just seem like coming to a stop takes alot of pedal.
  4. May 24, 2012 at 7:10 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :( In reading what you have posted, you may want to replace your flexible brake lines going to your front calipers. It sounds like the lines have collapsed inside the housing and you are trying to push bake fluid though a line that is collapsed inside. A small amount gets through, but it feels like you are having to stand on your brake pedal to make it work. You may want to change the rear flex lines at the same time to clear your system out. Your metal lines do not need replacing, unless you have damaged the lines off roading and kinked the lines. Good Luck.
  5. May 24, 2012 at 9:19 PM
    sir1123
    Charleston
    just ordered lines off wheelers before you posted that ha.. hopefully this will help
  6. May 25, 2012 at 9:29 AM
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    How many miles do you have on the truck? You may also have a faulty master cylinder that is starting to go out..
  7. May 25, 2012 at 4:58 PM
    sir1123
    Charleston
    220xxx
  8. May 26, 2012 at 11:07 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Sometimes gear oil leaks into the rear brakes from the differential. Toyota has made a technical service bulletin about this issue. I battled with it to the tune of $1000 on a 99 Trd 4x4 once. See if your parking brake works ok because it uses the rear brakes. If possible, pull the rear drums off and check for oil on the brake shoes. If the diff breather is clogged the fluid will go into the brakes, or if the axle bearings or seals are worn it will leak into the brakes.
    Another problem you might have is your brake master cylinder. You might see a fluid leak stain on the front of the brake booster if it's leaking. This will make you pedal go to the floor once in a while and could cause you to crash.
    If your calipers are rusty, the steel pins could get stuck. The calipers are supposed to move a bit.
    The brakes are probably the worst part of the 1st gen. taco. :(
  9. May 26, 2012 at 11:17 AM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    My caliper on my left side is seizing internally somehow. It is lubricated on the outside.
    That might be your problem.
    Also, if they are new pads, they need some time to set in.
    If you bled it in the wrong order, they might still have some air in them. I had that problem as well.
  10. May 26, 2012 at 5:08 PM
    sir1123
    Charleston
    what the proper bleeding order?
  11. May 26, 2012 at 6:26 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    rear passenger side, rear driver side, passenger side, driver side.
  12. May 27, 2012 at 6:35 PM
    koco
    Bay Area Ca.
    '01 Taco
    Yeah, you do this because you want to bleed the longest brake line first.
    Kennyk19 likes this.
  13. May 27, 2012 at 8:42 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Just bled mine today after putting on the new rear line, your fluid could also be really nasty and dirty causing it to clog up and make it harder to push the fluid through... Have you tried just flushing the whole system with fresh clean fluid?
  14. May 28, 2012 at 6:26 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Sorry don't have much technicality to add, but I recently replaced the front pads, rotors, bled and had new brake fluid put in the system two weeks ago. Before that my brakes had a very mushy feeling and would take almost all of the pedal play down to the floor pad to stop decently. Now after the above was replaced, not only does the truck stop in a much shorter distance, the pedal is firm and only takes about 1/4 to 1/2 pedal play to start stop significantly. Basically it feels like a whole other vehicle.
  15. May 28, 2012 at 12:40 PM
    Tylerm5000
    Tyler
    Oregon
    Good to hear it worked out for you! Brakes are not for the impatient person. :)
  16. May 28, 2012 at 2:02 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    and while you are flushing the system, it pays to go ahead and use DOT4, fluid, its only a dollar or 2 more but its worth it.
    and with abs systems, you should try to do this every 2 years or depending on use, when your fluid starts to become discolored.
    it will save you alot of aggravation in the long run.
  17. May 30, 2012 at 7:06 AM
    golstho
    golstho Member
    Alabama
    06 Tacoma
    i have a mushy pedal also and i have replaced the pads, shoes, fluid, and master cylinder. still have the problem mushy pedal that goes all the way to the floor and does not stop well. guess i should order lines and replace them.
  18. May 30, 2012 at 7:18 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    I bought the Wheeler's stainless brake lines from another TW member who bought, but did not use them. The fluid in my system was the original fluid and my brakes have always been a bit spongy. I decided to replace the fluid before I put the new lines on. What a difference just replacing the fluid made. The brakes have a totally different (better) feel to them and stop much better. Now I just need to put the new stainless lines on and I will be set.
    The bottom line...if you haven't ever flushed the brake system, do it. You won't regret it.
  19. May 30, 2012 at 10:30 AM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    thats what I have been preaching to people for years! 2 years max depending on use.
    if your brakes are still soft, I would first bled them again, and bled them long and hard. sometimes a pocket of air is hard to get out and thats all it takes.
  20. Jun 1, 2012 at 8:54 PM
    sir1123
    Charleston
    how do you flush the whole system?
