brakes feel like I'm pumping them
Discussion in 'Performance and Tuning' started by rondog, Dec 20, 2011.
  1. Dec 20, 2011 at 9:19 AM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    When I am slowing down to say a traffic light and I am lightly stepping on the brake pedal, my truck feels as if I am pumping the brakes. I only notice this going like >10mph. Its starting to get really annoying. Does anyone know what this can be? It feels like I am stepping hard on the brake, then letting off, then stepping hard, then letting off etc...
    Air in the brake lines?
    Bad rotors? pads?
  2. Dec 20, 2011 at 9:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    Does it feel like when the ABS system kicks in?
  3. Dec 20, 2011 at 9:26 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Warped rotor.
  4. Dec 20, 2011 at 9:32 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    when you sit at a stop light does the pedal just start dropping to the floor?
  5. Dec 20, 2011 at 9:39 AM
    rondog
    Ronnie
    Escondido/San Diego
    No, abs feels a lot rougher than what I am experiencing
    Nope
    The rotots i got are only 6 months old..damnit if it is warped
  6. Dec 20, 2011 at 9:40 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    what kinda rotors did you get?
  7. Dec 20, 2011 at 9:51 AM
    rondog
    Ronnie
    Escondido/San Diego
    ehhh uhhhh I got them at orieley's..use to be kragen, I cant remember the brand
  8. Dec 20, 2011 at 9:55 AM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    This!!
  9. Dec 20, 2011 at 10:15 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If your caliper seizes of sticks, it will keep the brakes applied or dragging. This will overheat and warp the rotors in short order.
    Either something was missed when the rotors were replaced, or something failed. I would focus on the work recently done.
    If you drive like a demon, or got cheap rotors, warping will happen quickly.
  10. Dec 20, 2011 at 10:20 AM
    beerye
    beerye Steel Curtain!!
    Brian
    Tucson, AZ
    02 TRD 4x4 5spd
    3" suspension lift 2009 Tacoma Alloys K&N Intake
    Rotors need to be turned. Do you remember when you last did them?
  11. Dec 20, 2011 at 10:21 AM
    beerye
    Brian
    Tucson, AZ
    02 TRD 4x4 5spd
  12. Dec 20, 2011 at 10:28 AM
    rondog
    Ronnie
    Escondido/San Diego
    Ok, I'll check the rotors..I dont think they need to be turned, I got them like 6 months ago
    Can anyone recommend a good rotor for our truck? even a more expensive one meant for larger tires. No ceramic or slotted rotors. I think that's overkill for me
  13. Dec 20, 2011 at 10:44 AM
    ST3VE
    MD --> SC
    I bought Brembo and they are great.
  14. Dec 20, 2011 at 10:48 AM
    beerye
    Brian
    Tucson, AZ
    02 TRD 4x4 5spd
    I went to Orielly and they now have rotors that have a lifetime warranty. I went with them and so far so good. I did also go ceramic pads too
  15. Dec 20, 2011 at 10:53 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    That's your problem.^
  16. Dec 20, 2011 at 11:11 AM
    rondog
    Ronnie
    Escondido/San Diego
    You know what...I am kinda leaning towards air in the brake lines. I changed my rear lines after I put my rear long travel on since I needed extended ones. I noticed it started happening after that and it seems to be progressively getting worse. Is that what air in the lines would feel like? I've kept an eye on the brake fluid and it hasn't gone down any since then
  17. Dec 20, 2011 at 12:22 PM
    4Wheelin4Banger
    Randy
    Air in the lines would make the brakes mushy IIRC.
  18. Dec 20, 2011 at 1:34 PM
    rondog
    Ronnie
    Escondido/San Diego
    ok then that must not be it...warped rotors from what you guys have been saying sounds like the issue here
  19. Dec 20, 2011 at 1:38 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    If their was air in the lines you would be able to push the brake pedal to the floor.
    Its a warped rotor.
    Maybe your riding your brakes or like others said a caliper is siezed in place and caused over heating
  20. Jan 1, 2012 at 5:15 AM
    johnny 5
    johnny 5 Well-Known Member
    wisconsin
    Black 07 TRD Off road 4x4
    7-6'' sno-way plow w/DP
    I got my rotors at napa and they have been on longer then the factory ones were and still no warpage or brake shimmy will for sure use them in the future again. I also used monroe disk pads in front and they have really held up very well a brand my local farm and fleet handles. I ALSO HAUL ALOT OF HEAVY LOADS AND CARRY A PLOW ON IT.
