brakes have pop sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by manny2115, Jan 29, 2010.
  1. Jan 29, 2010 at 10:06 AM
    manny2115
    manny2115 [OP] New Member
    bob
    texas
    2008 double cab prerunner
    Everytime I step on the brakes, there is a single pop sound. Sounds like a pad is sticking or loose in the caliper. Anybody have this problem?
    My 2001 Taco did it only in reverse, same sound. Got fix?:cool:
  2. Jan 29, 2010 at 10:09 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Got warranty?
  3. Jan 29, 2010 at 10:09 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    Oh totally, gotta change your blinker fluid. Then if that doesn't fix it (which of course it would!) i'd say you should make sure you've still got all the caps on your tire's valve stems. THEN you'd be golden ;)
    (just fuckin' with you ;) - i haven't seen that problem - make sure you have no mud or crap on them i guess? Pop those wheels off and take a lookie)
  4. Jan 29, 2010 at 10:19 AM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    I noticed a subtle sound coming from my breaks after I got my first oil change. Took it back to the dealer since they had "adjusted" the breaks. They could not reproduce the problem, of course.
    I later figured out the dealer pushed the A-Trac button on. I turned it off and stopped noticing that sound.
