Brakes jerking
Discussion in '1st Gen. Tacomas (1995-2004)' started by sthrnreb, Sep 25, 2017.
  1. Sep 25, 2017 at 9:27 AM
    sthrnreb
    sthrnreb [OP] Member
    Rebel
    2003Toyota Tacoma pre runner
    the brakes on my 2003 Toyota Tacoma Prerunner V6 are jerking when I come to a stop and I changed them twice how do I stop them form jerking?
  2. Sep 25, 2017 at 9:29 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    rotors are probably needing replacement
  3. Sep 25, 2017 at 9:33 AM
    sthrnreb
    Rebel
    Ok thank you
  4. Sep 25, 2017 at 10:32 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    What do you mean "jerking"??
    Do they lock up and un-lock as you are coming to a stop, or does the truck just vibrate (feel it through the brake pedal and steering wheel) when you apply the brakes? or something else?
  5. Sep 25, 2017 at 11:13 AM
    sthrnreb
    Rebel
    They vibrate is the best way to describe it yes. They used to lock up then unlock but I was sold the wrong brakes the first time I did them but I got the right ones this time and they are okay but now they vibrate like you said.
  6. Sep 25, 2017 at 11:27 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Although what you describe is usually due to front rotor runout or uneven pad material deposits (can be alleviated with machining but replacement is almost as cheap) my son's recent brake issue was due to out of round rear drums. The vehicle lurched and surged upon stopping instead of the typical steering wheel vibration at high speed (it had a little of this as well so all 4 corners were replaced). Stops like a dream now. But you NEED to clean the mating surfaces of the rotors/drums to hubs of any rust or debris that might prevent a perfect seat or you will soon have the same issues crop up.
  7. Sep 25, 2017 at 4:24 PM
    jbrandt
    Justin
    Did you just get brake pads or rotors too?
    The most common problem here is a warped rotor, but there are other things too.
    A few things I would check:
    It sounds like you did your own work, so make sure the surface where the rotor sits on the hub is perfectly clean (rotor and hub face). If there's even a small amount of dirt or grime in there, the rotor will NOT sit flat and it will wiggle and shake when you brake. If you are running old rotors, either get them machined flat, or just get new ones (decent ones don't cost that much more than a machine job). When you have your calipers off, check them over real good. Clean them up with some brake cleaner and see if you can see any signs that the pistons might be sticking, oil leaking, etc...
    sthrnreb[QUOTED][OP] likes this.
  8. Sep 25, 2017 at 4:38 PM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Warped rotors are very common on these trucks. Don't have them resurfaced. They'll be too thin and they'll warp again very quickly. Just get new ones. Brembos are cheap and pretty good.
    wilcam47 likes this.
  9. Sep 26, 2017 at 2:33 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Wyoming09, jbrandt and mechanicjon like this.
  10. Sep 26, 2017 at 7:21 PM
    Rob57
    Rob57 Member
    Rob
    2002 Toyota Tacoma TRD SR5
    I'm experiencing the same thing with my 2002 TRD SR5 ,just purchased it a few days ago and it's my first truck. Gonna check them out Friday when change my oil and change the shocks
  11. Sep 27, 2017 at 9:11 PM
    sthrnreb
    Rebel
    Had them done by a friend that knows how to do it and they stop beautiful now, thank you for all your help.
    wilcam47, mechanicjon and jbrandt like this.
