Brakes locked up AGAIN!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scrapla, Aug 4, 2016.
  1. Nov 10, 2021 at 5:30 AM
    #121
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Make sure the brake caliper lines are not twisted. Try pulling the ABS fuse or relay. See if anything noticeably better happens.
    JB92109 likes this.
  2. Nov 10, 2021 at 5:40 AM
    #122
    EME
    EME Well-Known Member
    Nick
    05 Tacoma sport
    if the brakes release when you pull the hose off the booster, it can only be the booster
    TRDSport10, 06Tacooo, JB92109 and 2 others like this.
  3. Nov 10, 2021 at 6:12 AM
    #123
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes. Very well could be that as well.
    JB92109 likes this.
  4. Nov 10, 2021 at 8:19 AM
    #124
    JB92109
    JB92109 Active Member
    Joe
    2007 Tacoma Sport 4 Door
    Rough Country Lift + 35" Mickey Thompson, Fab Fours Bumper, Superwinch 9.5k Talon, Dreamcatcher+Gunrack
    Thanks all - going to pick up from dealership now. Will give all this a try.
  5. Nov 13, 2021 at 6:33 AM
    #125
    Scrapla
    Scrapla [OP] Rebel Without a Clue
    South Florida
    2007 Tacoma PreRunner 4.0 V6
    1.5" lift, ARB bumper
    Keep me posted. After this issue happened the first time 5 years ago I bought a rebuilt OEM booster off Ebay which lasted for 5 years until one day I woke up to a dead battery and rock hard pedal. When I got a jump the pedal was very touchy and inconsistent and after 2 days the brakes locked up AGAIN on the highway and only releasing the vacuum hose released them. I have now installed a AutoZone booster because Toyota wants $900 for a new OEM unit.
    TRDSport10, 06Tacooo and Torspd like this.
  6. Nov 13, 2021 at 8:23 AM
    #126
    JB92109
    Joe
    I brought the truck to a local mechanic. He checked the linkage between the pedal and the booster / master cylinder and found that it was out of adjustment. That is weird, because ORW said they didn't touch that linkage when they did the install. Anyway, he compared it to a 2008 4-Runner he had on the lot, and said the adjustment was way off. After he readjusted that linkage the car drives fine. I hope this fixed the problem and it doesn't come back.
    06Tacooo likes this.
  7. Dec 9, 2021 at 6:59 PM
    #127
    Scrapla
    South Florida
    So after replacing all that I did my pads and rotors today only to find out I had a rusted out piston and horrible rotted dust boots on the others. Replaced calipers, rotors and pads. Hope this is the fix!
    cosmicfires and TRDSport10 like this.
  8. Jan 24, 2025 at 3:21 PM
    #128
    Scarpulalover
    Scarpulalover New Member
    So what was the fix? I have the exaxt same problem, both my front brakes seize radomly. I have checked every box. My question is was the galipper the problem or the vaccume
  9. Jan 24, 2025 at 3:26 PM
    #129
    Scrapla
    South Florida
    So I ended up replacing the brake booster and it's been fine since (knock on wood). When they lock up again get out of your truck and undo the vacuum from the booster while the trucks still running, if that frees up your brakes like it did for me then it's a bad booster. I really don't have a reason why it happens. This also happened to me years ago with my first car I ever owned.
  10. Jan 24, 2025 at 3:32 PM
    #130
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    These names too coincidental! It’s like I’m watching some guy talk to his hand! @Scrapla & @Scarpulalover same brake issues and everything! Freaky! Sorry… go on! Don’t mind me. Forget I was ever here.
    Scrapla[OP] likes this.
  11. Jan 24, 2025 at 3:35 PM
    #131
    Scrapla
    South Florida
    lol freaky eh? It's such a odd problem. I drove myself nuts trying to figure it out.
  12. Jan 24, 2025 at 4:20 PM
    #132
    Scarpulalover
    I made an account just for this! This legend had the same problem so i honnoured him..
    I am currently driving around to try and get my two front breaks to seize again.
    here is an idea: both of my front wheen axles are warm all the time. Maybe that after a certain distance they become hot enough so the heat expands the hydraulics or even galiper pistons or disc etc..
    I will uptate next time they seize
    Scrapla[OP] and Chunk[QUOTED] like this.
  13. Jan 24, 2025 at 4:23 PM
    #133
    Scrapla
    South Florida
    Ah good luck. My truck is just a 2WD so no front axles. Mine only locked up on the highway. In normal side streets they worked but the pedal felt very weird like it didn't have a consistent feel like it normally did. Once I replaced the booster everything went back to normal and the pedal felt great again.
