Brakes locking while driving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raynorshine15, Apr 20, 2023.
  1. May 7, 2023 at 10:02 PM
    Scrapla
    Scrapla Rebel Without a Clue
    South Florida
    2007 Tacoma PreRunner 4.0 V6
    1.5" lift, ARB bumper
    Yea mine is weird. It no longer locks up but I get a weird shudder only on the highway which you can feel in the wheel and at your feet and if you tap the brake pedal it's hard like you barely tap it and the brakes apply and shake but then it randomly goes away. It only happens on the highway. When I come to a stop on normal roads it's back to normal and don't get any shudder or shake like warped rotors would cause. I recently replaced my front bearings and noticed the inside pads and wearing more then the outside pads. Just odd they don't lock up and the shudder and hard pedal only happens on the highway on my nightly commute home.
  2. May 8, 2023 at 5:22 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Check your pads for even wear.
    If a pison gets stuck, it can cause inconsistent pressure on each side.
    Look if a spring that pushes the pad away from the rotor is rusted up
    Make sure the lug nuts are torqued evenly
  3. May 8, 2023 at 6:13 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Grease on the rotors and pads. Yes it can cause issues.
