Brakes not holding while rotating tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajwhlr04, Jul 15, 2013.
  1. Jul 15, 2013 at 4:16 PM
    ajwhlr04
    ajwhlr04 [OP] Well-Known Member
    Aaron
    Woodland Hills, CA
    2007 Tacoma 4x4 Double Cab 6MT
    So I rotated my tires on Sunday. After I got one side off the ground (and properly supported & parking brake on), I had my wife hop in the cab and hold the brakes so they wouldn't spin while getting the lug nuts off.
    After a few minutes of holding the brake pedal down, the brake pedal wouldn't hold the wheel in place anymore. It was possible that the pedal was to the floor, but my wire doesn't remember). This happened on the two front wheels (after I switched sides) since I had the parking brake set on the rear.
    It makes a squish sound when I depress the brake pedal - possibly coming from near the pedal or the master cylinder, which I recall hearing on just about every other car I've owned. For this reason, I didn't explore the sound further.
    The brakes seem to be working just fine when the engine is running.
    Is this all normal behavior? Specifically, the brakes not holding while turning lug nuts, with engine off?
    Thanks guys!
  2. Jul 15, 2013 at 4:18 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Takes a lot more pedal pressure with the engine off and no power assist, the reserve vacuum ran out.
    Your wife is weak. ;)
    I thought everyone knew to loosen the lugs before jacking up.
  3. Jul 15, 2013 at 4:18 PM
    pivey14
    pivey14 Well-Known Member
    Austin, TX
    2023 Lunar Rock TRD Off-Road 4x4
    Fuel Wheels Clash Bronze 6-Lug Wheel; 17x9; -12mm Offset 285/70/17 Nitto Ridge Grapplers 1” Front Spacer 2" Rear Block TRD Pro Grille with Raptor Lights TRD Pro Floor Liners TRD Pro Shifter Knob Lunar Rock Interior Trim BAMF Rock Sliders
    Yes. I'm assuming you are talking about your front tires. Mine move freely in the air as well even when brake is applied with e break. You just have to hold the tire while you remove the lugs.
  4. Jul 15, 2013 at 4:34 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    x2
  5. Jul 15, 2013 at 6:17 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    yep. loosen lugs a hair then jack up truck.
    your brakes are vacuum assisted. the big round black thing on the firewall behind the master cylinder. it houses a diaphragm that helps to "pull" the rod into the master when you apply the brakes. vacuum comes from your intake manifold. a good vehicle will have residual vacuum pressure after the vehicle is off. but its only good for one or two pumps, if that. then, you have to rely 100% on your own mite to push fluid with that tiny little master piston to push all those caliper pistons.
    remember in old cartoons when somebody would have to "stand" on the brakes for an emergency stop? that is what your wife would have needed to do to stop the wheels with no vacuum assist
  6. Jul 15, 2013 at 6:27 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    LOL and
    x3
  7. Jul 15, 2013 at 7:12 PM
    ajwhlr04
    Aaron
    Woodland Hills, CA
    Thanks guys.
    Yeah I forgot to loosen the lugs before jacking it up - both times. It was 100+ deg outside, and since I didn't have a tall enough hydraulic jack for the truck I resorted to the one that comes with the truck. I didn't feel like cranking on the jack any more than I had to.
    I'll be sure to tell my wife she's weak. :p
  8. Jul 16, 2013 at 12:46 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The "emergency Brake" only works on the rear wheels.
    It's Brake not break.:rolleyes:
