Brakes not working as they should (possibly)
Discussion in 'Technical Chat' started by gb42, Aug 21, 2013.
  1. Aug 21, 2013 at 1:02 PM
    gb42
    gb42 [OP] Well-Known Member
    Geoff
    WA State
    2016 MGM TRD OR DCSB MT
    Weird title I know, but here is my possible issue. It feels like I have to press the brakes really hard for the truck to stop and it is not smooth coming to a stop, it feels as if the ABS are kicking in like it will slow down, let up, slow down, let up etc. I do not get the shaky feeling of warped rotos.
    This wouldn't be due to worn pads, what else could cause this issue? Thanks.
    2008 Access Cab Automatic 40k miles.
  2. Aug 21, 2013 at 1:06 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Dont know if this helps but I had this problem when i first got my truck.....turns out that my huge foot was not pressing down on the brake pedal pad.......i was pushing down on the lever part of the pedal, way up above the pad on the brake
  3. Aug 21, 2013 at 1:10 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    your hub bearings are bad. my Pontiac Aztec has the same problem. we go through a set of four bearing about every 4 months, (btw Pontiac Aztecs are the biggest POS car i have ever had)
  4. Aug 21, 2013 at 1:15 PM
    gb42
    Geoff
    WA State
    Thanks for your replies, I am pretty sure I am pressing the pad but I will check to make sure.
    I will look into the hub bearings thing, I did a quick search and didn't see any 2nd gen topics on it.
  5. Aug 21, 2013 at 1:24 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Might want to bleed your brake lines. Only costs a few bucks and it's a simple procedure with a 2nd person.
  6. Aug 21, 2013 at 1:31 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It does sound like it could be bad bearings. While you're poking around under your truck you might as well manually adjust the drum brakes. Doesn't have to be done often, but worth it if you're already messing around with stuff. The auto adjusters don't do the greatest job.
  7. Aug 21, 2013 at 2:12 PM
    Zimaura
    Zimaura Well-Known Member
    Nj
    San jose, CA
    05 4x4 Double Cab. level Kit, 33 inch BFGs
    Level Kit, 16inch Moto Metals, 33 BFGs, Flowmaster, tinted taillights, silver billet grills
    I got a same problem with mine as well... want to find out why.
