Brakes oem vs aftermarket question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mallcrawler20, Nov 15, 2023.
  1. Nov 15, 2023 at 2:59 AM
    Mallcrawler20
    Mallcrawler20 [OP] Well-Known Member
    Trd off-road 4x4 Manual
    About that time to change the front brakes . Got about 45k miles out of the oem ones . What do u guys recommend for replacement oem or aftermarket . How many miles are u guys seeing out of the aftermarket ones . Thanks
  2. Nov 15, 2023 at 3:03 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    You only got 45k out of your oem pads or you're just changing them early?
    Chew likes this.
  3. Nov 15, 2023 at 3:04 AM
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    I'm also interested.
    What pads have the most bite? Brakes feel lacking now that I have 33's but don't want to upgrade to a big brake kit
  4. Nov 15, 2023 at 3:11 AM
    Mallcrawler20
    Starting to feel soft and brake noise . I do a lot of towing not surprised the brakes didn’t last that long .
    23MGM[QUOTED] likes this.
  5. Nov 15, 2023 at 3:37 AM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    Check out PowerStop Pads and slotted rotors.
    MKC1911 and Komurphy like this.
  6. Nov 15, 2023 at 3:45 AM
    MGMDesertTaco
  7. Nov 15, 2023 at 3:47 AM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    • StopTech 4Runner slotted rotors P/Ns
      126.44174SL, 126.44174SR
    • Advics P/N AD0976 OEM-equivalent pads with shims
    • PowerStop P/N S6278 reman
      4Runner calipers including all the hardware
    • OEM 4Runner brake dust shields
    • 4778160140, 4778260140 - they clear the All-Pro spindle gussets
    GunthorNC and embedded rock like this.
  8. Nov 15, 2023 at 5:17 AM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    The Raybestos E3 kits are great aftermarket sets for $100. ROCK AUTO RAYBESTOS 976H980670E3
    The pads have more bite than stock, and the rotors are fully coated to prevent corrosion. They are my go-to now. They seem to have a bit more black brake dust, but not a huge problem.
    They really helped on our highlander that has undersized brakes. I could feel the difference in braking performance right away.
    I had a set on my dad's tacoma, but he sold it with about 20kmi on the brakes. Currently have a set on my highlander with 30kmi and pilot with 40kmi on the brakes.
    They'll be going on my Tacoma when it needs them, but it's got a while.
    wayupnort likes this.
  9. Nov 15, 2023 at 5:20 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Pads don't go soft. They are as hard with 10mm as they are with 2mm. No need to replace pads with friction material remaining. Pads won't reduce your stopping distance. I stick with OE. Less dust and less squeal than aftermarket. I got 80k out of mine. Keep in mind there are two different qualities of dealer pads.
    Chew, ace_10 and 908tacoma like this.
  10. Nov 15, 2023 at 5:54 AM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    I wouldn't touch PowerStop anything after my last experience and there is no need for drilled or slotted rotors unless you have a heating issues and get a lot of brake fade. . . . . which I highly doubt. OEM are very good, but I will now be using Akebono
  11. Nov 15, 2023 at 7:25 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    OEM pads seem good.
    My choice for aftermarket has been Wagner for many years, they have a "Severe Duty" series that I use on trucks/heavy vehicles.
  12. Nov 15, 2023 at 8:38 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    OE and trailer brakes for the win!
    If you only got 45k out of the originals, something is wrong, address that before you look for something better.
  13. Nov 15, 2023 at 9:08 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    I just changed out my original fronts @ 116K. Went with Centric premium rotors and Beefed Up ceramic pads from Amazon. Just under $200 for the whole shebang. So far, so good, but we'll see how they hold up over time.
  14. Nov 15, 2023 at 9:14 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    70K or so. Rear shoes longer. OEM is best.
  15. Nov 15, 2023 at 9:28 AM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    WTF? I am at 117,000 miles and had to replace rears at 90,000 and have done fronts at least three times that I recall. OEM pads & shoes. I guess lots of trails and mud & crap destroy them faster
  16. Nov 15, 2023 at 10:04 AM
    RDT415
    RDT415 DUCTACO
    Sonoma County
    23 TRD Pro 6MT / past 04 DCSB 4WD
    Anyone tried the PowerBrake D line rotor/pad combo?
  17. Nov 15, 2023 at 10:44 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I swapped out brakes the day I got the truck with E36 pads and drilled/slotted rotors. I do a lot of off-roading and wanted to get as much dust/debris out of the way as fast as possible. I got about 32K out of the E36 pads. Just put my OE pads back on and am chewing through them faster than the E36. I'm okay with this as I know drilled/slotted rotors will do that, but my braking performance is superb.
  18. Nov 15, 2023 at 10:45 AM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    OEM quality rotors and good brake pads. That's all 97% of us "need". Don't get swayed by the hype.
    Chew likes this.
  19. Nov 15, 2023 at 10:52 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I normally like to stay with OEM but had a braking vibration at 40K mile. I put these PowerStop brakes on a year ago and very happy. I don’t tow or go off road.
    https://www.amazon.com/gp/product/B005FKS28C?ie=UTF8
