Brakes - Pads and Rotors
Discussion in 'Canada' started by HipHead, Oct 22, 2014.
  1. Jul 15, 2015 at 9:48 AM
    HipHead
    HipHead [OP] Well-Known Member
    Jeff
    Gilford, Ontario
    09 Access Cab V6 4L 6 Speed TRD Off Road
    Weathertech bug deflector, Uguard side step, tri-fold tonneau cover, Weathertech floor mats
  2. Aug 8, 2015 at 8:45 AM
    HipHead
    Jeff
    Gilford, Ontario
    Ended up going with oem rotors and pads. Still think the problem is at the front. Perhaps callipers.
    Regardless the new hardware will be installed.
    I should be able to clean up the caliper shims and pins. Is there other maintenance work I can do for callipers?
  3. Aug 18, 2015 at 9:40 AM
    HipHead
    Jeff
    Gilford, Ontario
    The drivers side caliper was seized. So instead of trying to make the old calipers work new calipers were installed.
    They are Napa auto remanufactured powder coated black.
    The Tacoma has new calipers, rotors and pads.
    Just curious what brake feel I should expect with the new hardware?
    Right now there is a slight soft spot with one pump of the brake pedal.
  4. Aug 18, 2015 at 9:48 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    The Tacoma brakes are slightly squishy overall. Did you make sure everything was bled out properly? I know it's a silly question but even a tiny bit of air in the cylinder can cause strange brake behavior that is expensive to fix.
  5. Aug 18, 2015 at 9:51 AM
    HipHead
    Jeff
    Gilford, Ontario
    What is the correct procedure to bleed brakes with new calipers?
  6. Aug 18, 2015 at 9:59 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    It's a two person operation and I think you have to start from the drivers side rear working in a circle until you get to the drivers side front. TBH I've never had to bleed the brakes in the Tacoma but I have heard that getting air in the master cylinder of the 2nd generation Tacoma is a hard fix. Hopefully a pro can chip in here.
  7. Aug 18, 2015 at 10:54 AM
    HipHead
    Jeff
    Gilford, Ontario
    Ok. Thanks. I am interested to know more.
    We definitely didn't do anything with rear brakes. (drums)
    Simply bleed both calipers passenger side first then divers side.
