Brakes pulsate
Discussion in '1st Gen. Tacomas (1995-2004)' started by pioneer59, Oct 4, 2009.
  1. Oct 4, 2009 at 7:25 AM
    pioneer59
    pioneer59 [OP] Member
    GREG
    Pioneertown, Ca
    04 Tacoma 4x4 SR5
    Hi all, I am new at this forum stuff. I am trying to find outwhy my brakes on my 04 Tacoma TRD 4x4 pulsate. I have turned the rotors and drums, new pads and still they pulsate. even turned the rotors again thinking the first shop didn't get them right. No luck. Is there something else going on with these 1st Gen Tacoma's I need to know about that causes the brakes to pulsate when braking?:confused:
  2. Oct 4, 2009 at 7:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!
    Its possible the wheels are unevely torqued.
  3. Oct 4, 2009 at 7:29 AM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    can you elaborate a little more on whats going on? i know what pulsate means, im just trying to figure out what and where you are feeling. like is the whole truck vibrating or can you just feel it at your foot? and is the pulsating affecting your braking in any way? i.e. taking longer to brake or shorter :confused:
  4. Oct 4, 2009 at 7:46 AM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    check the hat of the rotor the part where the lug holes are.this area gets rusty i always use a digrinder with a scotch brite pad.also you will need to get the hub clean also.if the area on the rotor was not cleaned then when machined the rotor was not true.also check the mounting surface on the backside of you wheels where the lug holes are.if your wheels are aluminium the do tend to get a little fuzzy that needs to be cleaned also.
  5. Oct 4, 2009 at 11:50 AM
    Carone
    Carone Well-Known Member
    NOR CAL
    LOOK HERE!!! 02 TRD xtra cab v6 4x4 white
    Look at my Build
    wheels arent balanced, ball joints a worn? wheels are over torqued? not mounted flush? or to thin and getting warped really fast. where is the pulsation? pedal, steering wheel, or seat?
  6. Oct 4, 2009 at 12:46 PM
    pioneer59
    GREG
    Pioneertown, Ca
    04 Tacoma 4x4 SR5
    The brakes vibrate and the steering column too, only when braking. No hard left or right, it is straight as an arrow. Just pulsates/vibrates when I brake. I tried pulling the E-brake only a few times and it stops smoothly, although takes forever as one would imagine when braking with the e-brake only. So that tells me the rear drum brakes are not the issue - although I did turn the drums anyway. Can a caliper piston be sticking? Or the anti-lock system be failing in some way?
  7. Oct 4, 2009 at 12:48 PM
    pioneer59
    GREG
    Pioneertown, Ca
    04 Tacoma 4x4 SR5
    Thank you very much jrf02. I will try these things!
    GREG
  8. Oct 4, 2009 at 1:02 PM
    cereal.killah
    cereal.killah got milk ?
    I would inspect around the front wheel area, look around the brake lines, where the line changes from a metal tube to rubber, look for kinks or a collapsed hose.
  9. Oct 4, 2009 at 1:06 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    OEM wheels? Aftermarket wheels? Have the wheels been balanced recently?
  10. Oct 4, 2009 at 2:35 PM
    jfr02
    i just hope it helps good luck.
  11. Oct 5, 2009 at 12:27 PM
    pioneer59
    GREG
    Pioneertown, Ca
    04 Tacoma 4x4 SR5
    I'll chek the lines too. The wheels are OEM and the tire size is the recommend 265/70/16. Nothing fancy, No lift.
  12. Oct 5, 2009 at 12:39 PM
    pioneer59
    GREG
    Pioneertown, Ca
    04 Tacoma 4x4 SR5
    Hi Carone, All those things you listed have been checked are are good! The pulsating is in the pedal and the steering wheel, only when braking!
  13. Oct 5, 2009 at 1:12 PM
    Carone
    NOR CAL
    Look at my Build
    I would say its not ABS issue, because you shouldnt feel it in the steering wheel just in the pedal. but i could be wrong.
    I would try to swap wheels around put the front on the rear and rear on the front and see if it changes.
    Also struts are tight and all alignment cam eccentric bolts are tight?
    even if the rotors have been turn it could still be the rotors. you might be down to getting new rotors. its definitely in the front though
  14. Oct 5, 2009 at 2:24 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    how old are the rotors? because if there old"ish" they might be warped?
    does the problem happen when your on the brakes hard?
    does it pull to one side?
    does it shake when your on them slightly?
    all signs of warped ones. or like chris said......uneven tourq on them
  15. Oct 5, 2009 at 2:55 PM
    ChrisYoTaCoMa
    ChrisYoTaCoMa Chrome's for Harleys and old farts
    Estero, Floriduh
    00 Taco 4x4 Ex cab 2.7 sr5 AT
    New Pioneer stereo, and all 4 speakers with Infinity components. Sirius satellite radio. Deckplate mod done. Door buzzer silenced forever thank God, tinted windows, vent visors, hood protector(bug guard), ceramic pads and new rotors, dechromed EVERYTHING. 2" Lift front 3" rear. Skyjacker AAL's and replacement leafs(and front spacers) from Fatbobsgarage.com. Skyjacker 7000 Hydro rear shocks, those Bilstein 5100 fronts are coming soon!
    I have the same issue, brand new rotors, new ceramic pads. Pulled my ebrake, at first I thought it was a bad drum, but when I brake the whole truck does the pulsating thing. Not really bad, but as it slows it is more obvious. I was going to return the rotors on warranty. The old rotors did the same thing, that's why I replaced them. It's driving me frickin nuts!!!
  16. Oct 6, 2009 at 10:04 AM
    pioneer59
    GREG
    Pioneertown, Ca
    04 Tacoma 4x4 SR5
    It happens with any braking, sometimes worse than others though. I can brake moderate one time and the pulsating is horrible and the next time it isn't so bad. It'll happen with light braking, yes I can feel it grabbing when slowing to a stop and you get that feel of brake grabbing on a certain spot when as the wheel rotates. Sometimes I feel like road conditions dicate the pulsation rate, doesn't make sense to me at all. I do need to try to retorque the wheels and see if that helps.
    GREG
  17. Oct 6, 2009 at 6:35 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I had a similar problem couple months ago. Bought some new rotors like 60 bucks stops like a dream now.
  18. Oct 6, 2009 at 6:49 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I had the same issue on an old 91 isuzu amigo. For me it turned out to be a sticking caliper piston. The pad would just slightly rub on the rotor. i could not tell it was rubbing but the brakes would get hot. when trying to stop, the brakes would pulsate. sometimes worse then other times.
  19. Oct 7, 2009 at 9:07 AM
    pioneer59
    GREG
    Pioneertown, Ca
    04 Tacoma 4x4 SR5
    I may have to take the caliber apart and hone out the positon cylinders to ensure this isn't an issue for me too.
    I retorqued the wheels but no good. Still pulsates.
  20. Oct 13, 2009 at 10:36 AM
    TattooedGirl
    TattooedGirl Well-Known Member
    Jae Jae
    Canton, MA
    04 Toyota Tacoma TRD 4x4
    I totally have the same issue in my 04 trd 4x4, I have been trying to figure it out but no luck. Took it in to Toyota and of course they say nothing is wrong because my truck has a 7 year warranty on it. Also, had someone check the brakes and they still have 25% life left. I have no clue whats going on....
