Brakes Pulsating Especially Downhill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheoBeidler, Nov 15, 2020.
  1. Nov 15, 2020 at 11:16 AM
    TheoBeidler
    TheoBeidler [OP] New Member
    Theo
    Buying - Looking like 2009 Blue Tacoma
    Hey all, I've had my '09 Taco for a few months now. Currently living in SoCal and have been driving through the mountains a good bit. Twice now on fairly steep and long downhills, I've noticed my brakes pulsating. Mainly through the steering column but feels like it shakes the whole truck and is audible as well. I don't think I've experienced any brake performance issues but both times I've pulled over and let them breathe a bit. Also it's a manual so I've relied a little more on downshifting to slow down at those times.
    Did a little research and seems like maybe a rotor issue? No issues under normal driving conditions, stock truck for the most part. Thinking I'll get rotors checked, anything else? Could probably do for a rotation anyways. Could it be a larger issue with brakes?
  2. Nov 15, 2020 at 11:20 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Replace rotors and pads.
  3. Nov 15, 2020 at 11:26 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I'd go with the rotors. Likely warped from high heat and cooling.
  4. Nov 15, 2020 at 11:28 AM
    Tttacodan
    Tttacodan Well-Known Member
    Dan
    Warped rotors for sure. Cheap an easy to replace. Good idea to also do the pads at the same time.
    Alexely999 and RedWings44 like this.
  5. Nov 15, 2020 at 11:35 AM
    TacoTuesday1
    FL
    In this thread,
    Forum advises to replace poorly-designed stock warp prone rotors,
    with another expensive $200 pair of the same poorly-designed rotors that will warp again
    because they are undersized for what the truck is
    as opposed to bigger 5th gen 4runner brakes, etc.
    Jenius
  6. Nov 15, 2020 at 11:37 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Use your gears properly on long downhills and you will never warp a set of rotors.
    RedWings44 likes this.
  7. Nov 15, 2020 at 11:38 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    how many total miles on truck
    how many since last brake job b4 U bought truck
    there are a few possibilities.....................the pads might be mismatched
    folks dont know OEM parts are matched !!
    many believe they can improve on stock......................
    ‘ box on shelf ‘ marketing sells products that are NOT always matched/better
    Alexely999 likes this.
  8. Nov 15, 2020 at 11:48 AM
    TacoTuesday1
    FL
    it will warp anyway
    the rotor size is smaller than the average sedan
    rear drum brakes don't help with that
    pretty sure 4runner calipers or better pads like TRD Ceramic with StopTech Cryo Slotted rotors are better
  9. Nov 15, 2020 at 6:52 PM
    nd4spdbh
    SoCal
    how is it that I had 100k on my original front rotors n pads driving ALL sorts of mtn roads with not a hint of a warped rotor? (hell just yesterday did an aggregate 5k feet of climbing / descending up n down mtn roads) I replaced both at 100k miles cus pads were donzo and whelp may as well replace rotors as they will go another 100k, but the rotors could of easily been reused.
    Needless to say Use your gears and brakes properly and you will never warp your rotors. Brakes are meant to bring a vehicle to a stop, gears are meant to hold a vehicle at speed (going up or downhill).
    Also the rear drums will almost always lockup the rear tires before the front disks so dont use that as an excuse.
    About the only time when one sees the limitations of the front stock brake setup is on tires bigger than 33s.
    Jimmyh likes this.
  10. Nov 15, 2020 at 6:53 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    As others have said, warped rotors
  11. Nov 15, 2020 at 6:59 PM
    Mossyjaws
    Mossyjaws Well-Known Member
    VA
    2015 dclb
    Footprint Gas Pedal
    Need to put brakes on mine for the first time. Have about 53k on the truck. Not squealing yet but can’t decide which rotors to get. Mine have been warped for awhile. Tow a fair amount. Pulled about 4200 lbs up and down a steep, long grade several times. Think that is likely where the issue with my rotors started.
