Brakes really touchy on my 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DiffLock, Oct 3, 2017.
  1. Oct 3, 2017 at 5:09 PM
    DiffLock
    DiffLock [OP] Well-Known Member
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Brakes are really touchy on my 3rd gen... especially off road, sometimes goes into a skid without wanting to. Is this common for 3rd gens?
  2. Oct 3, 2017 at 5:46 PM
    TRDOBSESSED
    TRDOBSESSED Well-Known Member
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    i think they are too...i talked to my dealer about it...normal of course
  3. Oct 3, 2017 at 7:04 PM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    good to know, thanks.
    TRDOBSESSED[QUOTED] likes this.
  4. Oct 3, 2017 at 7:09 PM
    TRDOBSESSED
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    i wasn't overly thrilled with their answer ....my truck will stop on a dime ,but like you said very touchy
  5. Oct 3, 2017 at 9:56 PM
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    Yup, my 3rd gen brakes do feel sensitive or touchy.
  6. Oct 3, 2017 at 10:09 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    TBDH, praise the Toyota engineers for better braking performance. Takes 5-10 min for any 2nd gen to fade with minimal pressure. Pedal travels 50% before it bites at anything. Learning to deal with a "touchy" brake over time is a lot better than remembering to brake an extra 500ft back from the stop light because heat is your worst enemy in an already squishy system.
    chrisrocks300 likes this.
  7. Oct 3, 2017 at 10:12 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My 2015 Off Road had insanely Touchy Brakes, the 2017 Off Road feels much less Touchy.
  8. Oct 3, 2017 at 11:00 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Normal
    Canadian Caber likes this.
  9. Oct 3, 2017 at 11:08 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    When I got mine in 2013 the brakes were super sensitive. It was hard going from driving it to driving my DD. After the first time I opened the brake system up to swap in SS extended lines the brakes went to what I would describe as "normal". Wasn't super sensitive, but the same as any other car I've driven. I'd be curious what they do at the factory to get them to that level of sensitivity.
    TireFire likes this.
  10. Oct 3, 2017 at 11:10 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    2nd and 3rd gen have the same brakes. Tire size and weight is a factor too. Sounds like you're due for some maintenance.
    PapaBear[QUOTED] likes this.
  11. Oct 3, 2017 at 11:46 PM
    PapaBear
    Austin
    SIN CITY
    To my knowledge, 3rd gen runs a hydro master while 2nd is vaccum but maybe I'm wrong. Yes, same size dual front piston and rotor size. I did just upgrade, maybe 5 months ago. EBC USR rotors and 7000 green stuffs along with new shoes and cylinders in the rear and hardware while I resurfaced the drums. Did the break in, no hard braking for the first 300 miles. About a month out I started to feel it fade again, even after short and minimal use. It's off an on TBH, pedal feel is dull, soft, and gets squishy quick. As said before, after minimal use, requires 50% pedal travel before it even starts to bite. For being green stuffs and not yellow, I was expecting the same amount of dust... These greens spray dust everywhere. My front wheels look like they're a brushed copper if I don't clean them. They are really silver. I'm hoping changing out the master will help along with doing a 4runner caliper and rotor swap in the near future, and maybe discs in the rear of I can find a viable kit or find a shop to make a bracket.
  12. Oct 4, 2017 at 12:06 AM
    shakerhood
    Southern Ohio
    Late 2nd and 3rd Gens share Brake Systems as ATRAC and Crawl Control is operated thru the Combo Brake Booster/MC, Off Road and Pro use this Style System. The SR, SR5, Sport, and Limited use Traditional Style Vacuum Boosters.
  13. Oct 4, 2017 at 12:27 AM
    PapaBear
    Austin
    SIN CITY
    So I was 50% right, I'll take it lol
    shakerhood[QUOTED] likes this.
  14. Oct 16, 2023 at 3:39 AM
    Dinasour73
    Dinasour73 Active Member
    Rickard
    2020 Tacoma Barcelona Red
    None
    I just bought 2020tacoma with 20,000 miles. On initial braking, brakes grab and throw driver forward.
    Just bled fluid, about 1 teaspoon from each caliper, without pedal pressure. Just slight drip.
    Road rested. Seems a bit more normal now. We'll see after about 1,000 mor miles. Any comment?
  15. Oct 16, 2023 at 4:14 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    I find the brakes not to be touchy at all I find that I have to apply more to the brakes to get it to stop . If u are skidding with slight brake input the brakes might be over adjusted .
    22Coma6MT likes this.
  16. Oct 16, 2023 at 4:22 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Just add 500lbs of armor and stuff. Problem solved.
  17. Oct 16, 2023 at 4:39 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    the brakes on my '22 taco are not touchy one bit. they're adequate but i consider them soft and weak vs. other trucks and cars we have/had.
    shakerhood likes this.
  18. Oct 16, 2023 at 5:35 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Brakes on my 2020 sr5 are normal like any other vehicles I've had. It's those trd models that the brakes are a bit weird. A buddy that had a 2019 trd had a time adjusting to the feel of the brakes in his truck. Those models have some weird quirks.
  19. Oct 17, 2023 at 3:44 AM
    Dinasour73
    Rickard
    None
    That's what I like. A moron
    TS4x4[QUOTED] likes this.
  20. Oct 17, 2023 at 4:44 AM
    TS4x4
    2018 TRD Offroad
    Momma always said I was special
    Taco y mas likes this.
