Brakes seized up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimthepianoman, Dec 29, 2024.
  1. Dec 29, 2024 at 4:31 PM
    jimthepianoman
    jimthepianoman [OP] New Member
    Jim
    2005 Toyota Tacoma
    Just bought this truck used 1 day ago. 2005 at 120,000 miles
    Drove it about 2 miles and parked overnight on a level driveway.
    Came out the next day and it won't move front or back.
    Of course I released the parking brake and the red light on the dash goes out.
    What could cause this.
    Any troubleshooting checklists or a flow chart.
    The seller was supposed to come over w his mechanic today - but couldn't make it.
    So...
    thank you,
    Jim
    buckhuntin-tacoma likes this.
  2. Dec 29, 2024 at 7:32 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW! Post your question in the 2nd Gen. section and you should get more responses.
    tcBob likes this.
  3. Dec 29, 2024 at 7:37 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’ll guess broken rr parking brake cable. Buy oe only. Good luck and welcome to TW!
    tcBob likes this.
  4. Dec 29, 2024 at 7:40 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    The parking brake can stick on. Especially with wet and cold conditions
    tcBob likes this.
  5. Dec 29, 2024 at 7:42 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Moved it over to the 2nd gen section from new members intro
  6. Dec 29, 2024 at 7:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Grab and shake each parking brake cable near the leaf springs. Sometimes they get dirt and water inside the sleeves and the cables inside will stick, holding the parking brake on.
    Lift each end of the truck and try to spin each wheel.
    If the rear drums are the problem you'll have to go in through the backing plate with a pick and/or pocket screwdriver and try to release tension at the star/adjuster wheel
    Good luck
  7. Dec 29, 2024 at 7:52 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    If the previous owner never used the parking brake, there's a good chance that the cable rusted and it won't release because of the corrosion. My wife never used the parking brake despite my constant reminder and when I moved it one day I put the brake on. When went back out to move it again, it wouldn't release. A tow to the dealer and a quick spray of something or other and I was back on the road.
    After that I just let her do what she wanted to.
  8. Dec 31, 2024 at 9:04 AM
    Pigpen
    Dan
    Northwest Montana
    Hi Jim
    This is a common tacoma issue. I had to replace my parking brake cables and have the rear brakes done on my 2012 for the same problem. If you crawl under the truck and look at the rear hub, you'll see that your parking brake cables are no longer securely connected to the hub. They corrode and crack, allowing moisture in. If you live in a cold area, they can ice up. If there's salt on the roads, they will rust. I would put it in 4 low and break them loose, then don't use the parking brake until you get it fixed. It's not a huge deal.
  9. Dec 31, 2024 at 2:45 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I drove a stick for many years and was in the habit of using the parking brake and it has carried over to my automatic. It's one of those things if you don't use it you will lose it and it will happen at an unexpected time.
