Brakes Shake Violently
Discussion in '1st Gen. Tacomas (1995-2004)' started by ShishkaBOMB, Feb 10, 2011.
  1. Feb 10, 2011 at 11:07 AM
    ShishkaBOMB
    ShishkaBOMB [OP] Well-Known Member
    My truck has had this problem for a while and it only happens under certain conditions.
    After a day's worth of driving to work and back home i leave the truck outside, everything is fine from the morning and when i get home.
    The problem occurs later at night when i want to pull the truck into my garage. The truck is cold by now and when i lightly step on the brakes to let the truck move slowly but not completely stopped, the truck shakes violently like a 7.0 earthquake!
    I have to step on the brakes completely until the truck stops to end the shaking. If i let off the brakes completely, the shaking stops. So i'm pretty sure its the brakes.
    I thought about it being because the brakes were cold, but it does not happen in the morning when i leave. So that makes me think it is because the brakes were hot and just began cooling or cooled down too fast.
    I looked at the brake pads and they are still brand new. The only problem i know of on the truck is the driveshaft center support bearing is completely blown but has been for a long time and i have not replaced it, not sure if this could cause it.
    Any help? Thanks!
  2. Feb 10, 2011 at 2:03 PM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    you might need new rotors and brake pads. sounds like your rotors could be warped from being heated then cooled off very quickly i.e. driving through a puddle after heavy braking
  3. Feb 10, 2011 at 2:53 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yep, sounds like rotors are warped & I would address that center bearing issue ASAP....:cool:
  4. Feb 10, 2011 at 3:02 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    it doesnt sound like the brakes to me ,you sure that drive shaft isnt jumping up and down making it shake?
  5. Feb 10, 2011 at 3:04 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    No it could be loose rotor or warped rotor. Does it only occur while braking?
  6. Feb 10, 2011 at 3:11 PM
    ShishkaBOMB
    Do you really think it is warped rotors?
    I've driven a car with warped rotors and it was different from this. I would also think that if it had warped rotors then it would shake all the time during normal driving.
    This only happens when i've driven the car for the day, let it sit for 4hours then drive it in.
    I'll try and get video if i can.
  7. Feb 10, 2011 at 3:14 PM
    ShishkaBOMB
    I do not brake to the point where the suspension is compressed causing the driveshaft to move up and down. But i thought of that, so first thing i will do is replace the center support bearing, just having trouble getting the driveshaft bolts off.
  8. Feb 10, 2011 at 3:26 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
  9. Feb 10, 2011 at 3:39 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Get under the truck and visibaly look everything over, then go from there.
  10. Feb 11, 2011 at 8:55 PM
    Skillet
    Skillet Well-Known Member
    Caleb
    Palmdale,Ca
    99 tacoma prerunner 3.4 auto trans trd,
    Trd edition,black powdercoated wheels,king Coils front, king double bypass rear, k&n cai, jba headers,borla exhuast,optima batt,xenon hid,crystal headlights,rewired entire car to four guage wiring on big stuff alt starter etc.,alpine screen,focal honeycomb components,JL four channel amp,dynamated entire inside of truck and hoodliner,limo tint all rear windows,LEDs everywhere possible dome light, tails,fronts,04 tailights,
    Piston in you're calipers ? One could be getting stuck a little maybe flush rebleed front calipers.
  11. Feb 11, 2011 at 9:45 PM
    thombiz
    thombiz Active Member
    Corpus Christi
    01 Prerunner & '02 Tundra
    I have the very same problem with my Tundra. Exact same problem! I have replaced the front rotors, calipers, pads and the rear cylinders. I think I've finally traced it down to the rear brakes being adjusted too tight. I pulled the drum today, inspected the springs, etc, and backed off the adjustment a bit, cleaned everything with brake parts cleaner and put it back together. As for the rotors, calipers and pads, I found hairline cracks in my Brembo rotors on the inside surface and it seemed time to replace the calipers (160k miles), just in case there was a rust pitting problem. Since the Tundra is an '02 I also replaced the cylinders and flushed the brake fluid. The problem went away, then came back after 2 weeks. I'll post more info as I determine if adjusting the brakes solved the serious shaking. So far it has, but I've been wrong before.
  12. Feb 11, 2011 at 9:59 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Does everyone have ABS ?? Could it be ?? :notsure::notsure: just throwing it out there...
  13. Feb 12, 2011 at 12:13 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    i bet this is the issue. i keep forgeting these trucks have rear drum brakes. i have had this happen on a 1934 ford coupe we built.
  14. Feb 12, 2011 at 7:18 AM
    thombiz
    Corpus Christi
    Two nights ago, the violent grabbing of the brakes started up again as I was pulling the Tundra into the garage for the evening. I inspected the driveway and thought I detected small black rubber patches on the driveway in an area which could have only been caused by the right rear tire. That is what lead me to inspect and re-adjust. So far, so good.
  15. Feb 13, 2011 at 8:49 PM
    thombiz
    Corpus Christi
    It's been a couple days now and the grabbyness is gone, so for me, it was having the rear brakes adjusted too tight which caused grabbyness at low speeds. It's good to have it fixed!
  16. Feb 14, 2011 at 2:13 PM
    ShishkaBOMB
    Thanks thombiz!
    I'm gonna take a look at it this weekend. Anyone have a link to a good howto or diy?
  17. Feb 15, 2011 at 9:13 AM
    HeadlampRevamp
    HeadlampRevamp Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Had similar issues. Truck would shake violently coming down from higher speeds when braking. Turned out my left caliper was sticking. Replaced both calipers, rotors, and pads.
  18. Feb 21, 2011 at 9:26 PM
    thombiz
    Corpus Christi
    Followup: It's been a week and no sign of any brake grabbyness at very low speeds like before. The rear brakes were adjusted too close, and backing them off has cured the problem.
