Brakes squeaking but not brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SargesaurusRex, Mar 30, 2023.
  1. Mar 30, 2023 at 7:47 PM
    SargesaurusRex
    SargesaurusRex [OP] New Member
    2014 Gray Tacoma PreRunner RWD
    Tonneau Cover
    I've had a consistent squeaking and a small lurch while braking from what I thought were warped rotors, however I just swapped both my rotors and my brake pads and the squeaking is still there. I checked my wheel bearings and it looks like just my front left wheel bearing is making a very slight noise but doesn't seem like it's the source of the squeaking as it's only apparent while braking. My next thought is to look into replacing the brake drums however the squeaking is coming from the front. I feel like it's a dual failure in the brake drums and the wheel bearings. Just wanted to check with y'all and see if anyone who has more years on this chassis might have some better ideas. Appreciate the response.
  2. Mar 30, 2023 at 8:46 PM
    Waasheem
    Waasheem
    2007 xrunner
    After replacing the pads & rotors was there any change in the noise? It’s not totally uncommon for new rotors to be warped. I had 1 so bad it couldn’t be cut true without going beyond minimum.
    Something you could try. Get the front end up on jack stands. Give the tires a tug, top to bottom in and out, left to right back and forth. There should be no clanking.
    Spin the tire while someone else gently gradually pushes the brake pedal. Try to figure out which side the noise is coming from. Then pull that tire. Put a couple lug nuts against the rotor. Give it a spin. Ideally use a dial gauge to see if it’s warped. I don’t have one, so I used a sharpie held against a wooden block so the tip is barely not touching. Push the sharpie tip closer while spinning the rotor until it does touch. That’ll give you an idea if it is warped and how bad.
  3. Mar 31, 2023 at 4:07 AM
    Falcoholic87
    Falcoholic87 Active Member
    2005 Tacoma
    Mine does this too. No lurch but the brakes squeak despite having fairly new pads. Brakes fine just squeaky
  4. Apr 2, 2023 at 12:47 AM
    hogfan1978
    hogfan1978 Well-Known Member
    Nacogdoches, TX
    08 TRD Sport 4x4 DC LB
    Wheel bearings can do funny things. Mine made a different noise when breaking due to the different loads put on them during breaking.
    Also, does yours have a driveshaft carrier bearing? Mine went out a few years ago and it was making a rather obnoxious squeaking noise.
    Get your wife to drive it while you listen from the outside to try and narrow down the location of the noise.
  5. Apr 2, 2023 at 5:30 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    How many miles on the truck?
  6. Apr 2, 2023 at 5:43 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    The rotor might be rubbing against the dust shield.
    bw4706 and stevesnj like this.
  7. Apr 2, 2023 at 7:37 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Brake dust shields can be a PITA - they can get tweaked by debris or impact, or eaten up the right way by rust and only catch under the right conditions. Get a good look at yours and see of that might be the case.
    My driver's side rattles in a really narrow RPM range at idle or park - getting ready to replace them when it warms up.
    super_white[QUOTED] likes this.
